Posting a new style and then putting (uploading) the sld file to this style does not work when the style has point in its name:
Working:
curl -v -u admin:geoserver -XPOST -H "Content-type: text/xml" -d "<style><name>fubar</name><filename>fubar.sld</filename><languageVersion><version>1.1.0</version></languageVersion></style>" [http://localhost:8080/geoserver/rest/styles](http://localhost:8080/geoserver/rest/styles)
curl -v -u admin:geoserver -XPUT -H "Content-type: application/vnd.ogc.se+xml" -d @fubar.sld [http://localhost:8080/geoserver/rest/styles/fubar?raw=true](http://localhost:8080/geoserver/rest/styles/fubar?raw=true)
Not working:
curl -v -u admin:geoserver -XPOST -H "Content-type: text/xml" -d "<style><name>foo.bar</name><filename>fubar.sld</filename><languageVersion><version>1.1.0</version></languageVersion></style>" [http://localhost:8080/geoserver/rest/styles](http://localhost:8080/geoserver/rest/styles)
curl -v -u admin:geoserver -XPUT -H "Content-type: application/vnd.ogc.se+xml" -d @fubar.sld [http://localhost:8080/geoserver/rest/styles/foo.bar?raw=true](http://localhost:8080/geoserver/rest/styles/foo.bar?raw=true)
Geoserver logfile is attached.
