[Geoserver-devel] [JIRA] (GEOS-8908) Wrong Coverage Parameter Type for OVERVIEW POLICY causing Coverage layer to be deleted from the Catalog upon reload of configuration or restart.
Steve Omondi created an issue
GeoServer / BugGEOS-8908
Issue Type:
BugBug
Affects Versions:
2.13.1
Assignee:
Unassigned
Components:
Configuration
Created:
28/Aug/18 11:10 AM
Priority:
HighHigh
Reporter:
Steve Omondi
When you set an Overview Policy in the Coverage parameters to any of the options, the parameter type is set to the full class name i.e. <org.geotools.coverage.grid.io.OverviewPolicy>QUALITY</org.geotools.coverage.grid.io.OverviewPolicy> as opposed to in earlier versions of Geoserver where this would be <string>QUALITY<string>.
This raises a Caused by: org.geoserver.config.util.SecureXStream$ForbiddenClassExceptionEx: Unauthorized class found, see logs for more details on how to handle it: org.geotools.coverage.grid.io.OverviewPolicy.
See full log:
018-08-28 09:42:16,297 ERROR [config.util] - Class org.geotools.coverage.grid.io.OverviewPolicy is not whitelisted for XML parsing.
This is done to prevent Remote Code Execution attacks, but it might be
you need this class to be authorized for GeoServer to actually work
If you are a user, you can set a variable named GEOSERVER_XSTREAM_WHITELIST
  with a semicolon separated list of fully qualified names, or patterns
  to match several classes.The variable can be set as a system variable,
  an environment variable, or a servlet context variable, just like
  GEOSERVER_DATA_DIR.
  For example, in order to authorize the org.geoserver.Foo class,
  plus any class in the org.geoserver.custom package, one could set
  a system variable:
  -DGEOSERVER_XSTREAM_WHITELIST=org.geoserver.Foo;org.geoserver.custom.**
If instead you are a developer, you can call allowTypes/allowTypeHierarchy against
  the XStream used for serialization by rolling a custom
  XStreamPersisterInitializer or customizing your XStreamServiceLoader.
2018-08-28 09:42:16,299 WARN [org.geoserver] - Failed to load resource
com.thoughtworks.xstream.converters.ConversionException:
---- Debugging information ----
cause-exception     : org.geoserver.config.util.SecureXStream$ForbiddenClassExceptionEx
cause-message       : Unauthorized class found, see logs for more details on how to handle it: org.geotools.coverage.grid.io.OverviewPolicy
class               : java.util.HashMap
required-type       : java.util.HashMap
converter-type      : com.thoughtworks.xstream.converters.collections.MapConverter
line number         : 155
class[1]            : org.geoserver.catalog.impl.CoverageInfoImpl
converter-type[1]   : org.geoserver.config.util.XStreamPersister$CoverageInfoConverter
version             : 2.13.1
        at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:79)
        at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:66)
        at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.unmarshallField(AbstractReflectionConverter.java:503)
        at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.doUnmarshal(AbstractReflectionConverter.java:429)
        at org.geoserver.config.util.XStreamPersister$ResourceInfoConverter.doUnmarshal(XStreamPersister.java:1923)
        at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.unmarshal(AbstractReflectionConverter.java:281)
        at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:72)
        at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:50)
        at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:134)
        at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:32)
        at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1486)
        at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1466)
        at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1346)
        at org.geoserver.config.util.XStreamPersister.load(XStreamPersister.java:633)
        at org.geoserver.config.GeoServerLoader.depersist(GeoServerLoader.java:961)
        at org.geoserver.config.GeoServerLoader$LayerLoader.accept(GeoServerLoader.java:193)
        at org.geoserver.config.GeoServerLoader.loadCoverageStore(GeoServerLoader.java:669)
        at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:558)
        at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:393)
        at org.geoserver.config.DefaultGeoServerLoader.loadCatalog(DefaultGeoServerLoader.java:36)
        at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:264)
        at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitialization(GeoServerLoaderProxy.java:59)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:409)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1620)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:555)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:483)
        at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
        at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
        at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
        at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
        at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:351)
        at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:108)
        at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:648)
        at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:145)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1193)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1095)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:513)
        at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:296)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1531)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1276)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:553)
        at org.geoserver.config.util.SecureXStream$DetailedSecurityExceptionWrapper.realClass(SecureXStream.java:175)
        at com.thoughtworks.xstream.mapper.MapperWrapper.realClass(MapperWrapper.java:125)
        at com.thoughtworks.xstream.mapper.CachingMapper.realClass(CachingMapper.java:47)
        at com.thoughtworks.xstream.core.util.HierarchicalStreams.readClassType(HierarchicalStreams.java:29)
        at com.thoughtworks.xstream.converters.collections.AbstractCollectionConverter.readItem(AbstractCollectionConverter.java:72)
        at com.thoughtworks.xstream.converters.collections.MapConverter.putCurrentEntryIntoMap(MapConverter.java:110)
        at com.thoughtworks.xstream.converters.collections.MapConverter.populateMap(MapConverter.java:98)
        at com.thoughtworks.xstream.converters.collections.MapConverter.populateMap(MapConverter.java:92)
        at com.thoughtworks.xstream.converters.collections.MapConverter.unmarshal(MapConverter.java:87)
        ... 122 more
Caused by: com.thoughtworks.xstream.security.ForbiddenClassException: org.geotools.coverage.grid.io.OverviewPolicy
        at com.thoughtworks.xstream.security.NoTypePermission.allows(NoTypePermission.java:26)
        at com.thoughtworks.xstream.mapper.SecurityMapper.realClass(SecurityMapper.java:74)
        at org.geoserver.config.util.SecureXStream$DetailedSecurityExceptionWrapper.realClass(SecureXStream.java:150)
        ... 131 more
This causes the coverage layer to be deleted from the catalog configuration upon catalog config reload or restart of geoserver.
This issue is likely related to GEOS-8642 which mention boolean being confused with string for some cases.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100090-sha1:78c6013)
Atlassian logo
