[Geoserver-devel] [JIRA] (GEOS-8924) GeoServer CQL cross layer filtering: querySingle/queryCollection for non-geometry attribute return
Katey Bilz created an issue
GeoServer / BugGEOS-8924
Issue Type:
BugBug
Affects Versions:
2.10.2
Assignee:
Unassigned
Components:
Querylayer, WMS
Created:
06/Sep/18 6:26 PM
Priority:
MediumMedium
Reporter:
Katey Bilz
I have only been able to find examples where geometry attributes are returned from cross layer filtering functions, but the GeoServer documentation says:
> A common use case is to extract a geometry-valued attribute, and then use the value(s) in a spatial predicate against a geometry attribute in the primary layer.
Which leads me to believe that it was intended to be used to return other data.
I have attempted something like this: http://localhost:8181/geoserver/test/wms?service=WMS&version=1.1.0&request=GetMap&layers=test:layer1,test:layer2&styles=&bbox=-81.54053,41.61621,-77.33826,43.41248&width=768&height=330&srs=EPSG:4326&format=application/openlayers&cql_filter=INCLUDE;property2a=querySingle(‘test:layer1’,‘property1b’,'property1a=123
Where only records in layer2 that have layer2.property2a = layer1.property1b are returned.
I get the exception: “Could not parse CQL filter list.”
Similarly: http://localhost:8181/geoserver/test/wms?service=WMS&version=1.1.0&request=GetMap&layers=test:layer1,test:layer2&styles=&bbox=-81.54053,41.61621,-77.33826,43.41248&width=768&height=330&srs=EPSG:4326&format=application/openlayers&cql_filter=INCLUDE;property2a IN queryCollection(‘test:layer1’,‘property1b’,‘INCLUDE’)
Where the values of layer2 will only be returned if layer2.property2a has a value in the returned values from layer1.property1b
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100091-sha1:8b1552e)
Atlassian logo
