[Geoserver-devel] [JIRA] (GEOS-8936) Long style names not readable in Additional Styles select
Torben Barsballe created an issue
GeoServer / ImprovementGEOS-8936
Issue Type:
ImprovementImprovement
Assignee:
Unassigned
Created:
18/Sep/18 12:45 AM
Priority:
MediumMedium
Reporter:
Torben Barsballe
If you have a long style name (longer than about 50 characters, depending on screen size, etc.), then the name of the style will overflow the select boxes for Additional Styles (in the WMS Settings section of the Publishing tab of the Layer Edit page), causing the latter part of the name to be hidden (See attached example).
This is particularly problematic if your style naming scheme is in ascending order of specificity, such that the first portion of your style names are all the same
These select boxes should be modified so the whole style name can be read.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100092-sha1:10a42af)
Atlassian logo
