[Geoserver-devel] [JIRA] (GEOS-8944) GWC fails to cache tiles if external GeoFence is used for authentication
Gnafu created an issue
GeoServer / BugGEOS-8944
Issue Type:
BugBug
Affects Versions:
2.13.2
Assignee:
Unassigned
Components:
GWC
Created:
24/Sep/18 10:28 AM
Environment:
GeoServer 2.13.2 with external GeoFence
Priority:
MediumMedium
Reporter:
Gnafu
GWC creates a mock request for the WMS to generate tiles to be cached, but it uses “127.0.0.1” as RemoteHost:
https://github.com/geoserver/geoserver/blob/master/src/gwc/src/main/java/org/geoserver/gwc/FakeHttpServletRequest.java#L303
This will make the WMS check for a rule about “127.0.0.1”, and not the actual IP of the request, changing the resulting image, or (if 127.0.0.1 is not allowed at all) failing to provide it.
The remote hostname and ip should be made available to the WMS that needs to render the tile.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100092-sha1:e9db01c)
Atlassian logo
