[Geoserver-devel] [JIRA] (GEOS-8946) Resolve format problems in community modules
Brad Hards created an issue
GeoServer / TaskGEOS-8946
Issue Type:
TaskTask
Affects Versions:
2.15
Assignee:
Brad Hards
Components:
Community modules
Created:
25/Sep/18 4:04 AM
Priority:
HighHigh
Reporter:
Brad Hards
Travis CI is failing for format checks in two community modules, even if no changes have been made
[INFO] Processed 31 files (1 non-complying).
[ERROR] Found 1 non-complying files, failing build
[ERROR] To fix formatting errors, run “mvn fmt:format”
[ERROR] Non complying file: /home/travis/build/geoserver/geoserver/src/community/wps-remote/src/main/java/org/geoserver/wps/remote/plugin/output/XMPPRawDataOutput.java
and
[INFO] Processed 9 files (1 non-complying).
[ERROR] Non complying file: /home/travis/build/geoserver/geoserver/src/community/security/keycloak/src/main/java/org/geoserver/security/keycloak/GeoServerKeycloakFilter.java
So it must be bad in master.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100092-sha1:5b0b49a)
Atlassian logo
