If I copy an existing style and assign it to the same layer it belong to, the GetCapabilities fails with a NullPointerException.
To reproduce:
- Start the platform independent binary package
- Go to http://localhost:8080/geoserver/topp/states/wms?service=WMS&version=1.3.0&request=GetCapabilities
- Notice the Layer is listed and the styles list is available
- Login to the admin panel
- Go to Styles and select “Add new style”
- Give it a name
- From “Copy from existing style” select “population” and hit “copy”
- Click “Apply”
- The “Publishing” tab should appear
- Open the “Publishing” tab
- In the “topp” “states” line, tick “Default” and “Associated” checkboxes
- Click Apply
- Go to http://localhost:8080/geoserver/topp/states/wms?service=WMS&version=1.3.0&request=GetCapabilities again
- Notice no styles are available
- Check the logs, see the NullPointerException
The log is:
22 ott 11:15:10 WARN [wms.capabilities] - Error writing metadata; skipping layer: states
java.lang.NullPointerException
at org.geoserver.ows.util.ResponseUtils.appendPath(ResponseUtils.java:209)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleLegendURL(Capabilities_1_3_0_Transformer.java:1408)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleStyles(Capabilities_1_3_0_Transformer.java:1091)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleLayer(Capabilities_1_3_0_Transformer.java:1035)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.doHandleLayer(Capabilities_1_3_0_Transformer.java:936)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleLayerTree(Capabilities_1_3_0_Transformer.java:896)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleLayers(Capabilities_1_3_0_Transformer.java:734)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleCapability(Capabilities_1_3_0_Transformer.java:478)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.encode(Capabilities_1_3_0_Transformer.java:288)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:996)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transformIdentity(TransformerImpl.java:659)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:728)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:343)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:284)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:119)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:101)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Response.write(Capabilities_1_3_0_Response.java:43)
at org.geoserver.config.CapabilitiesCacheHeadersCallback$RevalidateTagResponse.write(CapabilitiesCacheHeadersCallback.java:144)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:1032)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:268)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:174)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:967)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:901)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:73)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:37)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:317)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:70)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:51)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:141)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:347)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:263)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:90)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:79)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:215)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:110)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:499)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
at java.lang.Thread.run(Thread.java:748)
