[Geoserver-devel] [JIRA] (GEOS-8983) GeoFence Server Plugin prevents GeoServer from starting
Gnafu created an issue
GeoServer / BugGEOS-8983
Issue Type:
BugBug
Affects Versions:
2.14.0
Assignee:
Unassigned
BUG_GEOFENCE.txt
Components:
GeoFence
Created:
23/Oct/18 4:01 PM
Environment:
Windows 10, Java 1.8.0_191
Priority:
MediumMedium
Reporter:
Gnafu
I tested the latest release with the GeoFence Server Plugin and GeoServer failed to start with a FileNotFoundException
To reproduce:
Please find attached the GeoServer log.
Here is an extract:
2018-10-23 15:43:54.732:INFO:geoserver:main: Initializing Spring root WebApplicationContext
23 ott 15:43:56 WARN [geoserver.config] - Error reading resource URL [jar:file:/G:/work/GeoSolutions/GeoServer/geoserver-2.14.0/webapps/geoserver/WEB-INF/lib/gs-geofence-server-2.14-SNAPSHOT.jar!/geofence-default-override.properties]
java.io.FileNotFoundException: URL [jar:file:/G:/work/GeoSolutions/GeoServer/geoserver-2.14.0/webapps/geoserver/WEB-INF/lib/gs-geofence-server-2.14-SNAPSHOT.jar!/geofence-default-override.properties] cannot be resolved to absolute file path because it does not reside in the file system: jar:file:/G:/work/GeoSolutions/GeoServer/geoserver-2.14.0/webapps/geoserver/WEB-INF/lib/gs-geofence-server-2.14-SNAPSHOT.jar!/geofence-default-override.properties
at org.springframework.util.ResourceUtils.getFile(ResourceUtils.java:215)
at org.springframework.core.io.AbstractFileResolvingResource.getFile(AbstractFileResolvingResource.java:53)
at org.springframework.core.io.UrlResource.getFile(UrlResource.java:213)
at org.geoserver.config.SpringResourceAdaptor.relative(SpringResourceAdaptor.java:35)
at org.geoserver.config.GeoServerPropertyOverrideConfigurer.setLocations(GeoServerPropertyOverrideConfigurer.java:49)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.beans.BeanWrapperImpl$BeanPropertyHandler.setValue(BeanWrapperImpl.java:354)
at org.springframework.beans.AbstractNestablePropertyAccessor.processLocalProperty(AbstractNestablePropertyAccessor.java:467)
at org.springframework.beans.AbstractNestablePropertyAccessor.setPropertyValue(AbstractNestablePropertyAccessor.java:290)
at org.springframework.beans.AbstractNestablePropertyAccessor.setPropertyValue(AbstractNestablePropertyAccessor.java:278)
at org.springframework.beans.AbstractPropertyAccessor.setPropertyValues(AbstractPropertyAccessor.java:95)
at org.springframework.beans.AbstractPropertyAccessor.setPropertyValues(AbstractPropertyAccessor.java:75)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1570)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1284)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:553)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:483)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:312)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:308)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:202)
at org.springframework.context.support.PostProcessorRegistrationDelegate.invokeBeanFactoryPostProcessors(PostProcessorRegistrationDelegate.java:151)
at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:687)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:525)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:443)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:325)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:22)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:800)
at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:444)
at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:791)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:294)
at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1349)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1342)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:741)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:505)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:41)
at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:186)
at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:498)
at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:146)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:180)
at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:440)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:64)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:609)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:528)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:391)
at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:313)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:150)
at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:560)
at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:235)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:132)
at org.eclipse.jetty.server.Server.start(Server.java:387)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:114)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:61)
at org.eclipse.jetty.server.Server.doStart(Server.java:354)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1255)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1174)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:321)
at org.eclipse.jetty.start.Main.start(Main.java:817)
at org.eclipse.jetty.start.Main.main(Main.java:112)
23 ott 15:43:56 WARN [geoserver.config] - Error reading resource ServletContext resource [/$
{geofence-ovr}]
java.io.FileNotFoundException: ServletContext resource [/${geofence-ovr}
] cannot be resolved to absolute file path - web application archive not expanded?
at org.springframework.web.util.WebUtils.getRealPath(WebUtils.java:274)
at org.springframework.web.context.support.ServletContextResource.getFile(ServletContextResource.java:176)
23 ott 15:43:56 INFO [config.GeoServerPropertyOverrideConfigurer] - Properties resource not found: Could not open ServletContext resource [/$
{geofence-ovr}
ott 23, 2018 3:43:57 PM org.geoserver.platform.GeoServerExtensions extensionNames
AVVERTENZA: bean lookup error
org.springframework.beans.factory.CannotLoadBeanClassException: Error loading class [org.geoserver.monitor.hib.HibernateMonitorDAO2] for bean with name 'hibMonitorDAO' defined in URL [jar:file:/G:/work/GeoSolutions/GeoServer/geoserver-2.14.0/webapps/geoserver/WEB-INF/lib/gs-monitor-hibernate-2.14-SNAPSHOT.jar!/applicationContext-hib2.xml]: problem with class file or dependent class; nested exception is java.lang.NoClassDefFoundError: org/geoserver/monitor/MonitorDAO
at org.springframework.beans.factory.support.AbstractBeanFactory.resolveBeanClass(AbstractBeanFactory.java:1394)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.determineTargetType(AbstractAutowireCapableBeanFactory.java:641)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.predictBeanType(AbstractAutowireCapableBeanFactory.java:609)
at org.springframework.beans.factory.support.AbstractBeanFactory.isFactoryBean(AbstractBeanFactory.java:1490)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.doGetBeanNamesForType(DefaultListableBeanFactory.java:425)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeanNamesForType(DefaultListableBeanFactory.java:395)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeanNamesForType(DefaultListableBeanFactory.java:389)
at org.springframework.context.support.AbstractApplicationContext.getBeanNamesForType(AbstractApplicationContext.java:1176)
at org.geoserver.platform.GeoServerExtensions.extensionNames(GeoServerExtensions.java:198)
at org.geoserver.platform.GeoServerExtensions.extensions(GeoServerExtensions.java:116)
at org.geoserver.platform.GeoServerExtensions.bean(GeoServerExtensions.java:306)
at org.geoserver.config.GeoServerLoaderProxy.lookupGeoServerLoader(GeoServerLoaderProxy.java:72)
at org.geoserver.config.GeoServerLoaderProxy.setApplicationContext(GeoServerLoaderProxy.java:39)
at org.springframework.context.support.ApplicationContextAwareProcessor.invokeAwareInterfaces(ApplicationContextAwareProcessor.java:121)
at org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:97)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:409)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1626)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:555)
at org.springframework.context.support.PostProcessorRegistrationDelegate.registerBeanPostProcessors(PostProcessorRegistrationDelegate.java:237)
at org.springframework.context.support.AbstractApplicationContext.registerBeanPostProcessors(AbstractApplicationContext.java:703)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:528)
Caused by: java.lang.NoClassDefFoundError: org/geoserver/monitor/MonitorDAO
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:763)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:467)
at java.net.URLClassLoader.access$100(URLClassLoader.java:73)
at java.net.URLClassLoader$1.run(URLClassLoader.java:368)
at java.net.URLClassLoader$1.run(URLClassLoader.java:362)
at java.net.URLClassLoader.findClass(URLClassLoader.java:361)
at org.eclipse.jetty.webapp.WebAppClassLoader.findClass(WebAppClassLoader.java:510)
at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:441)
at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:403)
at org.springframework.util.ClassUtils.forName(ClassUtils.java:251)
at org.springframework.beans.factory.support.AbstractBeanDefinition.resolveBeanClass(AbstractBeanDefinition.java:401)
at org.springframework.beans.factory.support.AbstractBeanFactory.doResolveBeanClass(AbstractBeanFactory.java:1438)
at org.springframework.beans.factory.support.AbstractBeanFactory.resolveBeanClass(AbstractBeanFactory.java:1383)
... 71 more
Caused by: java.lang.ClassNotFoundException: org.geoserver.monitor.MonitorDAO
at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:450)
... 87 more
BUG_GEOFENCE.txt
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100094-sha1:a459261)
Atlassian logo
