[Geoserver-devel] [JIRA] (GEOS-8990) Mapbox vector tiles inconsistent rendering across zoom levels
Devon Tucker created an issue
GeoServer / BugGEOS-8990
Issue Type:
BugBug
Assignee:
Unassigned
Components:
Vector Tiles
Created:
29/Oct/18 5:45 PM
Priority:
MediumMedium
Reporter:
Devon Tucker
When viewing point layers with MVT, there is significant “jiggle” when zooming in. To recreate, just view any point layer (sf:bugsites for example) in openlayers using MVT and zoom in.
I tried playing with the oversampling that was already present in vectortiles, but it did not seem to fix the issue. What did fix the issue was increasing the render area significantly for MVT tiles, thus “rendering” the tiles at a higher resolution. This also has the added benefit of matching Mapbox’s default tile extent, which is 4096 (probably to avoid the same issues) as detailed here:
https://github.com/mapbox/vector-tiles/issues/45
I have a partial fix for this in the works that I’m hoping to get around to finishing. The issue is mainly with the test cases, it fails on finding too many features in a request. I suspect the paint area is being used somewhere on a filter when retrieving features:
https://github.com/dvntucker/geoserver/blob/mvt_extent_issue/src/extension/vectortiles/src/main/java/org/geoserver/wms/vector/VectorTileMapOutputFormat.java
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100094-sha1:3cac95f)
Atlassian logo
