James Meeks created an issue |
Issue Type: |
Bug |
Affects Versions: |
2.10.2 |
Assignee: |
Unassigned |
Components: |
WMS |
Created: |
30/Oct/18 7:19 PM |
Environment: |
Oracle 11g (11.2.0.4) |
Priority: |
Medium |
Reporter: |
EPSG:404000 not acting correctly. WKT is as listed below in provided GeoServer Files: Units should be in meters according to this, but when using this epsg code with meters in the bounding box you get: However when using degrees in the bounding box you get a correct response without issue. This also affects the application of the SLD file, causing the styling to become unstable at certain zoom levels. For example: When zoomed all the way out. WKT for this EPSG code should be updated and tested. |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100094-sha1:9c5bdd0) |
