Daniele Romagnoli created an issue |
LogFactory conflict in gs-main Eclipse project results into unable to compile/run. |
Issue Type: |
Bug |
Assignee: |
Components: |
Main |
Created: |
12/Nov/18 6:32 PM |
Priority: |
Medium |
Reporter: |
When trying to build and run GeoServer from Eclipse as imported modules, there is a conflict preventing its startup. Running “mvn dependency:tree” on gs-main I see: … Both commons-logging:commons-logging and org.springframework:spring-jcl define Therefore, depending on which order the jars are loaded, you may be unable to have it work. I’ll be back with a PR containing an exclusion in the gs-main pom.xml |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100095-sha1:93136a0) |
