[Geoserver-devel] [JIRA] (GEOS-9036) Some rendering transformations do not benefit from advanced projection handling and dateline wrapping
Lubomír Bucek created an issue
GeoServer / BugGEOS-9036
Issue Type:
BugBug
Affects Versions:
2.14.1
Assignee:
Unassigned
Components:
WMS
Created:
27/Nov/18 8:24 PM
Priority:
MediumMedium
Reporter:
Lubomír Bucek
Rendering transformations generating raster data do not benefit from the “advanced projection handling” and “dateline wrapping” machinery, as such they can only render the true source locations, but do not get replicated across the dateline.
First image shows global pressure with cut raster on date line. (webmercator) This example layer uses Ras:Jiffle.
https://www.dropbox.com/s/7yi3fg1zjb58fed/pressure.png?dl=0
Second image shows global temperature. This example layer does not use Jiffle.
https://www.dropbox.com/s/b09t4v3bbjrrggg/temp.png?dl=0
Queried BBOX is extended webmercator BBOX in the X coordinate around 1.5 times and is the same for both examples: &bbox=-3.00360832789244E7%2C-2.00496140146E7%2C3.00375042789244E7%2C2.005866104014594E7
Part of SLD style for pressure: Jiffle for example divides pressure by 100. Contours are drawn outside of bbox even though Jiffle is used for them too, while ColorMap is not.
<FeatureTypeStyle>
<Transformation>
<ogc:Function name=“ras:Jiffle”>
<ogc:Function name=“parameter”>
<ogc:Literal>coverage</ogc:Literal>
</ogc:Function>
<ogc:Literal>script</ogc:Literal>
<ogc:Literal>
pres = src[0];
dest = pres / 100.0;
</ogc:Literal>
</ogc:Function>
</ogc:Function>
</Transformation>
<Rule>
<RasterSymbolizer>
<Opacity>0.4</Opacity>
<ColorMap>
<ColorMapEntry color=“#FFFFFF” quantity=“950” opacity=“1” />
<ColorMapEntry color=“#9380F7” quantity=“960” opacity=“1” />
<ColorMapEntry color=“#7986f8” quantity=“970” opacity=“1” />
<ColorMapEntry color=“#6EB7F8” quantity=“980” opacity=“1” />
<ColorMapEntry color=“#60CDF6” quantity=“985” opacity=“1” />
<ColorMapEntry color=“#51F1F4” quantity=“990” opacity=“1” />
<ColorMapEntry color=“#3BF49D” quantity=“995” opacity=“1” />
<ColorMapEntry color=“#9AF32D” quantity=“1000” opacity=“1” />
<ColorMapEntry color=“#DAF32B” quantity=“1005” opacity=“1” />
<ColorMapEntry color=“#F3CA27” quantity=“1010” opacity=“1” />
<ColorMapEntry color=“#F2641E” quantity=“1015” opacity=“1” />
<ColorMapEntry color=“#DD151E” quantity=“1020” opacity=“1” />
<ColorMapEntry color=“#85093E” quantity=“1030” opacity=“1” />
<ColorMapEntry color=“#180112” quantity=“1040” opacity=“1” />
</ColorMap>
</RasterSymbolizer>
</Rule>
<FeatureTypeStyle>
</FeatureTypeStyle>
<Transformation>
<ogc:Function name=“ras:Contour”>
<ogc:Literal>data</ogc:Literal>
</ogc:Function>
<ogc:Literal>
pres = src[0];
</ogc:Literal>
</ogc:Function>
</ogc:Function>
</ogc:Function>
<ogc:Literal>levels</ogc:Literal>
levels…
Issue from gis stackexchange also linked to this:
https://gis.stackexchange.com/questions/303023/geoserver-sld-contours-fail-to-draw-some-times-when-panning-using-layer-preview
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100095-sha1:0eeea27)
Atlassian logo
