[Geoserver-devel] [JIRA] (GEOS-9042) TileMatrixSets' supported CRS are ignored when consuming WMTS service
Henrik Pierrou created an issue
GeoServer / BugGEOS-9042
TileMatrixSets’ supported CRS are ignored when consuming WMTS service
Issue Type:
BugBug
Affects Versions:
2.14.1
Assignee:
Unassigned
Created:
30/Nov/18 12:11 PM
Priority:
HighHigh
Reporter:
Henrik Pierrou
When creating a WMTS store and publishing layers from that store, Geoserver seems to ignore the supported CRS’s set in the TileMatrixSets and always thinks the native SRS is WGS84 (4326). I have tried the following WMTS services:
http://geodata.nationaalgeoregister.nl/luchtfoto/infrarood/wmts?request=GetCapabilities&service=WMTS
http://wmts.kartetirol.at/wmts
https://api.lantmateriet.se/open/topowebb-ccby/v1/wmts/token/8d61b10d-e93b-3c04-b4ae-4f4bdd1afe1b/?request=getcapabilities&service=wmts
In my case I need to use the last of the three services (api.lantmateriet.se) and publish a SWEREF99 (3006) layer. The service provides one TileMatrixSet supporting WGS84/Pseudo-mercator (3857) and one supporting SWEREF99 (3006). Trying to reproject to or force the use of the declared SWEREF99 creates a broken map with overlapping tiles (this somehow works for 3857 though).
A couple of things worth noting:
The tokens in the URL’s will get invalidated after a while but the data is open so anyone can create an account at https://opendata.lantmateriet.se and generate their own.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100095-sha1:323e10a)
Atlassian logo
