2018-12-16 10:16:08,701 ERROR [geotools.io] - Error attempting to close a mapped byte buffer : java.nio.DirectByteBuffer
JVM : 11.0.1 Oracle Corporation
java.lang.IllegalAccessException: class org.geotools.resources.NIOUtilities$1 cannot access class jdk.internal.ref.Cleaner (in module java.base) because module java.base does not export jdk.internal.ref to unnamed module @606fc505
at java.base/jdk.internal.reflect.Reflection.newIllegalAccessException(Reflection.java:361)
at java.base/java.lang.reflect.AccessibleObject.checkAccess(AccessibleObject.java:591)
at java.base/java.lang.reflect.Method.invoke(Method.java:558)
at org.geotools.resources.NIOUtilities$1.run(NIOUtilities.java:218)
at org.geotools.resources.NIOUtilities$1.run(NIOUtilities.java:206)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at org.geotools.resources.NIOUtilities.clean(NIOUtilities.java:205)
at org.geotools.data.PrjFileReader.close(PrjFileReader.java:161)
at org.geotools.data.PrjFileReader.<init>(PrjFileReader.java:90)
at org.geotools.data.PrjFileReader.<init>(PrjFileReader.java:62)
at org.geotools.data.shapefile.ShapefileSetManager.openPrjReader(ShapefileSetManager.java:101)
at org.geotools.data.shapefile.ShapefileFeatureSource.readAttributes(ShapefileFeatureSource.java:523)
at org.geotools.data.shapefile.ShapefileFeatureSource.buildFeatureType(ShapefileFeatureSource.java:479)
at org.geotools.data.shapefile.ShapefileFeatureStore.buildFeatureType(ShapefileFeatureStore.java:137)
at org.geotools.data.store.ContentFeatureSource.getAbsoluteSchema(ContentFeatureSource.java:328)
at org.geotools.data.store.ContentFeatureSource.getSchema(ContentFeatureSource.java:297)
at org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:293)
at org.geotools.data.directory.DirectoryDataStore.getSchema(DirectoryDataStore.java:100)
at org.geotools.data.directory.DirectoryDataStore.getSchema(DirectoryDataStore.java:164)
at org.geotools.data.directory.DirectoryDataStore.getSchema(DirectoryDataStore.java:51)
at org.geoserver.catalog.ResourcePool.getCacheableFeatureType(ResourcePool.java:960)
at org.geoserver.catalog.ResourcePool.tryGetFeatureType(ResourcePool.java:939)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:922)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:916)
at org.geoserver.catalog.ResourcePool.loadAttributes(ResourcePool.java:792)
at org.geoserver.catalog.ResourcePool.getAttributes(ResourcePool.java:767)
at org.geoserver.catalog.impl.FeatureTypeInfoImpl.attributes(FeatureTypeInfoImpl.java:119)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:128)
at com.sun.proxy.$Proxy34.attributes(Unknown Source)
at org.geoserver.wms.WMS.isWmsExposable(WMS.java:1830)
at org.geoserver.gwc.layer.CatalogConfiguration.isLayerExposable(CatalogConfiguration.java:455)
at org.geoserver.gwc.config.GWCInitializer.createDefaultTileLayerInfos(GWCInitializer.java:234)
at org.geoserver.gwc.config.GWCInitializer.initialize(GWCInitializer.java:106)
at org.geoserver.config.GeoServerLoader.loadInitializers(GeoServerLoader.java:298)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:277)
at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitialization(GeoServerLoaderProxy.java:54)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:409)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1626)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:555)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:483)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:312)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:308)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:351)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:108)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:648)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:145)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1201)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1103)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:513)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:761)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:867)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:543)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:443)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:325)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:22)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:800)
at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:444)
at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:791)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:294)
at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1349)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1342)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:741)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:505)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:41)
at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:186)
at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:498)
at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:146)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:180)
at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:440)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:64)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:609)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:528)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:391)
at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:313)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:150)
at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:560)
at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:235)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:132)
at org.eclipse.jetty.server.Server.start(Server.java:387)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:114)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:61)
at org.eclipse.jetty.server.Server.doStart(Server.java:354)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1255)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1174)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:321)
at org.eclipse.jetty.start.Main.start(Main.java:817)
at org.eclipse.jetty.start.Main.main(Main.java:112)
2018-12-16 10:16:10,288 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘KMLEncoder’: Failed to introspect bean class [org.geoserver.kml.KMLEncoder] for lookup method metadata: could not find class that it depends on; nested exception is java.lang.NoClassDefFoundError: javax/xml/bind/JAXBException
at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.determineCandidateConstructors(AutowiredAnnotationBeanPostProcessor.java:269)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.determineConstructorsFromBeanPostProcessors(AbstractAutowireCapableBeanFactory.java:1126)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1099)
Caused by: java.lang.NoClassDefFoundError: javax/xml/bind/JAXBException
at java.base/java.lang.Class.getDeclaredMethods0(Native Method)
at java.base/java.lang.Class.privateGetDeclaredMethods(Class.java:3167)
at java.base/java.lang.Class.getDeclaredMethods(Class.java:2310)
at org.springframework.util.ReflectionUtils.getDeclaredMethods(ReflectionUtils.java:613)
at org.springframework.util.ReflectionUtils.doWithMethods(ReflectionUtils.java:524)
at org.springframework.util.ReflectionUtils.doWithMethods(ReflectionUtils.java:510)
at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.determineCandidateConstructors(AutowiredAnnotationBeanPostProcessor.java:247)
… 57 more
Caused by: java.lang.ClassNotFoundException: javax.xml.bind.JAXBException
at java.base/java.net.URLClassLoader.findClass(URLClassLoader.java:471)
at org.eclipse.jetty.webapp.WebAppClassLoader.findClass(WebAppClassLoader.java:510)
at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:441)
at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:403)
… 64 more
