Richard Duivenvoorde created an issue |
Issue Type: |
Bug |
Affects Versions: |
2.14.1 |
Assignee: |
Unassigned |
Attachments: |
test4dz28992.nc |
Components: |
NetCDF |
Created: |
14/Jan/19 9:23 PM |
Priority: |
Medium |
Reporter: |
To reproduce:
Attached nc file is a valid coarse/CF epsg:28992 netcdf with a time and a z dimension. Trying to create a netcdf store from it OUTSIDE the geoserver_data_dir fails. But as soon as you move the exact same netcdf file somewhere inside the geoserver_data_dir creation of the store + layers + dimensions works! Not sure if this is a known issue, but as the gui of the creation of a netcdf store is able to browse to your home dir etc it would be better if this worked, OR this possibility is removed (so only browsing inside the geoserver_data_dir is possible)? |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100097-sha1:20c71fe) |
