[Geoserver-devel] [JIRA] (GEOS-9145) GetLegendGraphic in JPEG will fail if libjpeg-turbo is installed
Gnafu created an issue
GeoServer / BugGEOS-9145
Issue Type:
BugBug
Affects Versions:
2.14.1
Assignee:
Unassigned
Created:
11/Mar/19 4:54 PM
Environment:
GeoServer 2.14.1 with LibJPEG-turbo plugin
Tested with LibJPEG-turbo 1.5.3, 2.0.0 and 2.0.2
Windows and Linux
Priority:
MediumMedium
Reporter:
Gnafu
Trying to get a JPEG legend with the libjpeg-turbo enabled will produce the following error:
<?xml version="1.0" encoding="UTF-8"?><ServiceExceptionReport version="1.3.0" xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/ogc http://localhost:8080/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd">   <ServiceException>
      java.lang.IllegalStateException: No compression type set!
</ServiceException></ServiceExceptionReport>
And this stack trace is logged:
11 mar 11:57:39 INFO [geoserver.servlets] - OutputStream was successfully aborted.
11 mar 11:57:39 ERROR [geoserver.ows] -
        at javax.imageio.ImageWriteParam.setCompressionQuality(ImageWriteParam.java:1243)
        at org.geoserver.wms.legendgraphic.JAISupport.encode(JAISupport.java:166)
        at org.geoserver.wms.legendgraphic.JPEGLegendGraphicResponse.write(JPEGLegendGraphicResponse.java:42)
        at org.geoserver.ows.Dispatcher.response(Dispatcher.java:1032)
        at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:268)
        at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:174)
        at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
        at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:967)
        at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:901)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
        at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
        at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
        at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669)
        at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26)
        at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652)
        at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69)
        at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:73)
        at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66)
        at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
        at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:37)
        at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:317)
        at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:70)
        at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
        at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
        at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74)
        at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
        at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)
        at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
        at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:51)
        at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
        at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
        at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81)
        at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
        at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
        at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214)
        at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177)
        at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:141)
        at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:347)
        at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:263)
        at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:90)
        at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:79)
        at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
        at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
        at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
        at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)
        at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
        at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
        at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
        at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
        at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
        at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
        at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
        at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:215)
        at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:110)
        at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
        at org.eclipse.jetty.server.Server.handle(Server.java:499)
        at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
        at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
        at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
        at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
        at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
        at java.lang.Thread.run(Thread.java:748)
I tested this with libjpeg-turbo version 1.5.3, 2.0.0 and 2.0.1
I also tried to test the latest 2.16.x but I got a different error that prevents any legend to appear, even without the libjpeg-turbo library and plugin installed.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100099-sha1:c406023)
Atlassian logo
