[Geoserver-devel] [JIRA] (GEOS-9147) Geoserver does not calculate the extent correctly
Fadi created an issue
GeoServer / BugGEOS-9147
Issue Type:
BugBug
Assignee:
Unassigned
Created:
13/Mar/19 10:24 AM
Environment:
Geoserver 2.15.0, Postgres 11.2, PostGis 2.5.1 (ubuntu 11.2-1)
Priority:
MediumMedium
Reporter:
Fadi
Hallo,
we have the above-named Geoserver, PostGis and the following table:
\d waterway.waterway_axis
Table “waterway.waterway_axis”
Column
Type
Collation
Nullable
default
id
integer
not null
generated by default as indentity
wtwaxs
geography(LineString,4326)
not null
objnam
character varying
not null
nobjnam
character varying
Indexes:
“waterway_axis_pkey” PRIMARY KEY, btree (id)
Check constraints:
“waterway_axis_wtwaxs_check” CHECK (st_issimple(wtwaxs::geometry))
Opening layer preview from the administration interface and then opening waterway_axis layer does not show the features right in the box(lines and polygons) what is expected.
we must zoom out to see the layer then move to the right coordinates and again zoom in to show it.
another observation:
getting the values from the db with :
select st_extent(wtwaxs::geometry) from waterway.waterway_axis;
st_extent
BOX(13.3886796784167 48.0908715400774,17.1462820066055 48.5922161670332)
and entering these values manually into geoserver (edit layer from admin interface)------>> all worked as expected (we can see the features without zooming in and out), so that we have right extent.
compute from data button in the Edit layer admin interface calculates wrong values
the values in fields are following:
Min X: 0.637170732021332, Min Y:0.152935296297073, Max X:0.645281612873077, Max Y:0.197139039635658
which leads to do not show the correct extent of the layer in layer preview
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100099-sha1:ba6e856)
Atlassian logo
