[Geoserver-devel] [JIRA] (GEOS-9187) web-app can no longer use jetty:run as packaging changed to jar
Jody Garnett created an issue
GeoServer / BugGEOS-9187
Issue Type:
BugBug
Affects Versions:
2.15.0
Assignee:
Jody Garnett
Components:
release
Created:
23/Apr/19 7:38 PM
Priority:
MediumMedium
Reporter:
Jody Garnett
Last week we ran a GeoServer developer workshop at foss4gna and ran into the following glitch, our QuickStart instruction provides the following steps:
cd geoserver/src
mvn install -DskipTests -T 2C
cd web/app
mvn jetty:run
The last step fails as the packaging for web/app is “jar” rather than “war”:
[INFO] --- jetty-maven-plugin:9.4.12.v20180830:run (default-cli) @ gs-web-app ---
[INFO] Logging initialized @7015ms to org.eclipse.jetty.util.log.Slf4jLog
[INFO] Skipping GeoServer Web Application : packaging type [jar] is unsupported
Changing it to “war” allows us to run, but then the maven install fails:
[ERROR] Failed to execute goal org.codehaus.mojo:build-helper-maven-plugin:1.8:attach-artifact (attach-war) on project gs-web-app: Execution attach-war of goal org.codehaus.mojo:build-helper-maven-plugin:1.8:attach-artifact failed: For artifact {org.geoserver.web:gs-web-app:2.15-SNAPSHOT:war}: An attached artifact must have a different ID than its corresponding main artifact. -> [Help 1]
I was unable to untangle this by providing a classifier to build-helper-maven-plugin:
<artifact>
  <classifier>war</classifier>
  <file>${project.build.directory}/geoserver.war</file>
  <type>war</type>
</artifact>
After this change both mvn install and mvn jetty:run work; but I am concerned for any downstream application depending on gs-web-app as a jar.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100099-sha1:be996a2)
Atlassian logo
