[Geoserver-devel] [JIRA] (GEOS-9192) GeoServer UI let's you save duplicate grids names
Gnafu created an issue
GeoServer / BugGEOS-9192
GeoServer UI let’s you save duplicate grids names
Issue Type:
BugBug
Affects Versions:
2.12.1, 2.15.0, 2.16-RC
Assignee:
Unassigned
Components:
GWC
Created:
29/Apr/19 6:49 PM
Priority:
MediumMedium
Reporter:
Gnafu
A Gridset with duplicate grid names will cause referencing issues, for example:
  • Duplicate an existing Gridset
  • Set a few grid names all the same string
  • Apply that gridset to a layer
  • Open the tile layers preview for that layer
  • Zoom in
Since the grids have the same name, the first matching will be used even if the client is sending the coordinates of a different grid.
The client will use what is told to use according to the WMTS GetCapabilities.
The server will assume the client is requesting an out of bound tile.
The GeoServer UI should prevent the user from input duplicate grid names, or at least inform the user that issues may arise.
Example of bad configuration:
<scaleNames>
<string>GlobalCRS84Pixel:14</string>
<string>GlobalCRS84Pixel:8</string>
<string>GlobalCRS84Pixel:9</string>
<string>GlobalCRS84Pixel:10</string>
<string>GlobalCRS84Pixel:11</string>
<string>GlobalCRS84Pixel:12</string>
<string>GlobalCRS84Pixel:13</string>
</scaleNames>
Example of a request from the demo page:
http://localhost:8080/geoserver/gwc/service/wmts?layer=topp%3Astates&style=&tilematrixset=My_GlobalCRS84Pixel&Service=WMTS&Request=GetTile&Version=1.0.0&Format=image%2Fpng&TileMatrix=GlobalCRS84Pixel%3A14&TileCol=5&TileRow=2
Response:
<ExceptionReport version="1.1.0" xmlns="http://www.opengis.net/ows/1.1"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/ows/1.1 [http://geowebcache.org/schema/ows/1.1.0/owsExceptionReport.xsd](http://geowebcache.org/schema/ows/1.1.0/owsExceptionReport.xsd)">
<Exception exceptionCode="TileOutOfRange" locator="TILECOLUMN">
<ExceptionText>Column 5 is out of range, min: 0 max:0</ExceptionText>
</Exception>
</ExceptionReport>
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100100-sha1:4e86e56)
Atlassian logo
