[Geoserver-devel] [JIRA] (GEOS-9212) GeoFence Internal Server plugin gives NPE when run from web/app
Torben Barsballe created an issue
GeoServer / BugGEOS-9212
Issue Type:
BugBug
Assignee:
Unassigned
Components:
GeoFence
Created:
13/May/19 7:48 PM
Priority:
MediumMedium
Reporter:
Torben Barsballe
The geofence-server profile does not work properly when running from the demo web app - the beans in geofence-services-impl-3.4.2.jar/applicationContext.xml do not get loaded at startup, leading to NPEs on all of the GeoFence admin pages.
For example:
Caused by: java.lang.NullPointerException
    at org.hibernate.impl.SessionFactoryImpl.getClassMetadata(SessionFactoryImpl.java:807)
    at com.googlecode.genericdao.search.hibernate.HibernateMetadataUtil.get(HibernateMetadataUtil.java:92)
    at com.googlecode.genericdao.dao.jpa.JPABaseDAO._all(JPABaseDAO.java:206)
    at com.googlecode.genericdao.dao.jpa.GenericDAOImpl.findAll(GenericDAOImpl.java:61)
    at org.geoserver.geofence.core.dao.impl.RuleDAOImpl.findAll(RuleDAOImpl.java:101)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
    at java.lang.reflect.Method.invoke(Method.java:498)
    at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:343)
    at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:198)
    at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163)
    at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:294)
    at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:98)
    at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
    at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:212)
    at com.sun.proxy.$Proxy39.findAll(Unknown Source)
    at org.geoserver.geofence.services.RuleAdminServiceImpl.getAll(RuleAdminServiceImpl.java:189)
    at org.geoserver.geofence.web.GeofenceRulesModel.<init>(GeofenceRulesModel.java:99)
    at org.geoserver.geofence.web.GeofenceServerPage.<init>(GeofenceServerPage.java:68)
    ... 124 more
I have been able to reproduce this when running the web app through Intellij, with both the geofence and geofence-server profiles enabled, as well as through maven, using mvn jetty:run -Pgeofence,geofence-server
Note: This does not affect a normal WAR install of the GeoFence Internal Server plugin.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100101-sha1:5e04bb1)
Atlassian logo
