[Geoserver-devel] [JIRA] (GEOS-9218) Parameter Exctractor plugin prevents the Monitor plugin to log requests
Gnafu created an issue
GeoServer / BugGEOS-9218
Issue Type:
BugBug
Affects Versions:
2.15.1
Assignee:
Unassigned
Components:
Monitoring
Created:
15/May/19 6:42 PM
Priority:
MediumMedium
Reporter:
Gnafu
If the Parameter Extraction plugin and the Monitor Plugin are installed, every request that is rewritten by the Parameter Extraction plugin is not logged in the Monitoring Plugin audit files.
To reproduce:
The second request does not shows up in the logs even if it returns the correct image.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100102-sha1:417a414)
Atlassian logo
