[Geoserver-devel] [JIRA] (GEOS-9219) gwc tile layer load performance regression at startup
Gabriel Roldan created an issue
GeoServer / BugGEOS-9219
Issue Type:
BugBug
Affects Versions:
2.15.1
Assignee:
Gabriel Roldan
Components:
GWC
Created:
16/May/19 2:33 AM
Priority:
MediumMedium
Reporter:
Gabriel Roldan
DefaultTileLayerCatalog listens to Resouce events under
the data directory’s gwc-layers folder resource in order to
notify its local instance listeners of tile layer configuration
changes even when on a shared directory by several service
instances.
To do so, it uses both a “folder” listener on gwc-layers,
and one listener per tile layer info resource (i.e. gwc-layers/*.xml).
This results in a severe startup hit when there are several
tile layers.
A pull request has already been applied on master (https://github.com/geoserver/geoserver/pull/3451) and needs to be backported to 2.15.x. 2.14.x is not affected.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100102-sha1:417a414)
Atlassian logo
