“Failed to Retrieve User 557058:0a4da8ef-2b69-4bc7-96db-59a6b046f967” created an issue |
Geopackage raster table with dots in the name cannot be added |
Issue Type: |
Bug |
Affects Versions: |
2.15.1 |
Assignee: |
Unassigned |
Components: |
geopackage |
Created: |
24/Jun/19 5:56 PM |
Environment: |
macOS Mojave, OpenJDK 8 |
Priority: |
Medium |
Reporter: |
“Failed to Retrieve User 557058:0a4da8ef-2b69-4bc7-96db-59a6b046f967” |
If a Geopackage raster table name contains dots, it cannot be added as layer and will throw errors: {{Could not list layers for this store, an error occurred retrieving them: Failed to create reader from file:///Users/stefan/sources/bigtiff/gpkg/relief.with.dots.gpkg and hints Hints: REPOSITORY = org.geoserver.catalog.CatalogRepository@anonymised.com EXECUTOR_SERVICE = java.util.concurrent.ThreadPoolExecutor@anonymised.com[Running, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 0] System defaults: STYLE_FACTORY = StyleFactoryImpl FORCE_LONGITUDE_FIRST_AXIS_ORDER = true FEATURE_FACTORY = org.geotools.feature.LenientFeatureFactoryImpl@anonymised.com FORCE_AXIS_ORDER_HONORING = http GRID_COVERAGE_FACTORY = GridCoverageFactory TILE_ENCODING = null LENIENT_DATUM_SHIFT = true FILTER_FACTORY = FilterFactoryImpl COMPARISON_TOLERANCE = 1.0E-8 Error log: {{24 Jun 17:46:59 DEBUG [org.geotools.geopkg] - SELECT a.*, c.organization_coordsys_id, c.definition FROM gpkg_contents a, gpkg_spatial_ref_sys c WHERE a.srs_id = c.srs_id AND a.data_type = ? |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100105-sha1:87838dc) |
