[Geoserver-devel] [JIRA] (GEOS-9302) WFS axis order inconsistency between Geoserver's documentation and implementation
Robin Houtmeyers created an issue
GeoServer / BugGEOS-9302
WFS axis order inconsistency between Geoserver’s documentation and implementation
Issue Type:
BugBug
Affects Versions:
2.15.2
Assignee:
Unassigned
Components:
Documentation, WFS
Created:
06/Aug/19 6:21 PM
Priority:
MediumMedium
Reporter:
Robin Houtmeyers
According to the axis ordering section in the documentation page
https://docs.geoserver.org/latest/en/user/services/wfs/basics.html#wfs-basics-axis, the following assumptions are used:
EPSG:xxxx => longitude/latitude (x/y)
http://www.opengis.net/gml/srs/epsg.xml#xxxx => longitude/latitude (x/y)
urn:x-ogc:def:crs:EPSG:xxxx => latitude/longitude (y/x)
In practice, this doesn’t hold for EPSG:xxxx. Try for instance the following request for the default sample data tiger:poi:
http://demo.luciad.com/geoserver/ows?SERVICE=WFS&TYPENAMES=tiger:poi&VERSION=1.1.0&REQUEST=GetFeature
The result is latitude/longitude. Although this is correct according to the EPSG database, it does conflict with the documentation; I assume the latter should be updated?
Note: to test this, you have to adjust the WFS service to let it use the EPSG notation; by default, the URN notation is used.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100107-sha1:a6aabc9)
Atlassian logo
