[Geoserver-devel] [JIRA] (GEOS-9351) Artefacts when projecting EPSG:4326 Geotiff raster data in EPSG:3413 (North Pole stereographic).
Jeroen van Gent created an issue
GeoServer / BugGEOS-9351
Issue Type:
BugBug
Affects Versions:
2.15.2, 2.16.0
Assignee:
Unassigned
Created:
30/Sep/19 1:54 PM
Environment:
I have originally asked this question here: https://gis.stackexchange.com/questions/336977/artefacts-gaps-in-tiles-from-geoserver and was advised to file a report.
The problems involves GeoTiff EPSG 4326 raster data that I let GeoServer reproject through WMS requests into an Arctic Stereographic map (EPSG 3413) from a LEaflet application. When zooming in, tiles that have one corner on the antimeridian show missing data. Note that projections in Web Mercator (EPSG 5857) are fine, so the data is there in the GeoTiff file. The WMS “Enable Advanced Projection handling” is ticked, but when unticked, additional triangular artefacts appear (no surprise there, I guess).
Some images to illustrate the problem:
An example GeoTiff file can be found here:
The applied style can be found here, but the problem also occurs with the default GeoServer raster style applied.
Thank you for looking into this
Priority:
MediumMedium
Reporter:
Jeroen van Gent
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100111-sha1:316e470)
Atlassian logo
