Michael Weber created an issue |
Conversion from boolean true/false in geoserver to SQL Server bit 0/1, is broken |
Issue Type: |
Bug |
Affects Versions: |
2.16.0 |
Assignee: |
Unassigned |
Components: |
SQLServer |
Created: |
24/Oct/19 5:45 PM |
Priority: |
Medium |
Reporter: |
Hi When working with a layer from a SQL server that contains a bit WFS-T updates fail when the update contains the boolean. I have tried sending both 0/1 and true/false. WFS-T error Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Invalid column name ‘false’. It also fails to render if you make a filter in the SLD using the bit/boolean. |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100114-sha1:a15da00) |
