[Geoserver-devel] [JIRA] (GEOS-9385) GWC initialization thrashes CPU and filesystem at startup
Gabriel Roldan created an issue
GeoServer / ImprovementGEOS-9385
Issue Type:
ImprovementImprovement
Assignee:
Gabriel Roldan
Components:
GWC
Created:
28/Oct/19 4:47 PM
Priority:
MediumMedium
Reporter:
Gabriel Roldan
During system startup, GeoServer’s GWC initialization does parallel loading of tile layer config objects on the ForkJoinPool.commonPool() which by one side thrashes the file system with many (as in as many cores) I/O threads, and by the other side is heavily locked on XStream synchronized blocks, as all threads share a single XStream instance for unmarshalling of GeoServerTileLayerInfo objects.
Once that’s done, GWCInitializer loads all GeoServer LayerInfo and LayerGroupInfo objects from the catalog into an in-memory list and traverses it again on the ForkJoinPool.commonPool() to find which tile layers are not to be in-memory cached by GWC’s CacheProvider. Although this doesn’t incur in any I/O, wastes memory and processing power when there’s no need to fetch all catalog’s layers and layergroups into an ArrayList.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100114-sha1:6a0801f)
Atlassian logo
