[Geoserver-devel] [JIRA] (GEOS-9399) Oracle SQL View with NULL SRID breaks Bounds calculations on BasicResourceConfig
Imran Rajjad created an issue
GeoServer / BugGEOS-9399
Issue Type:
BugBug
Affects Versions:
2.17-RC
Assignee:
Imran Rajjad
Components:
UI
Created:
12/Nov/19 10:06 AM
Fix Versions:
2.16.1
Priority:
MediumMedium
Reporter:
Imran Rajjad
When creating an SQL View without SRS, the BasicResourceConfig page still tries to guess the Native SRS, resulting in strange behavior and throwing error
Error getting actual Native SRS code for resource ADRESSER: java.lang.NullPointerException
Steps to Re-produce
-Run Geoserver with Oracle Datastore enabled
-Create Oracle table with SDO Geometry, Metadata entry and index following example Oracle SDO Geometry Example
-Create an SQL View using SQL (select * from COLA_MARKETS)
-Don’t set the SRID and submit the view
-Verify log error Error getting actual Native SRS code for resource ADRESSER: java.lang.NullPointerException`
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100114-sha1:9fc4561)
Atlassian logo
