Pierre Noll created an issue |
Issue Type: |
Bug |
Affects Versions: |
2.15.2 |
Assignee: |
Unassigned |
Attachments: |
web.xml |
Components: |
Configuration |
Created: |
17/Nov/19 2:49 PM |
Environment: |
Docker image kartoza/geoserver:2.15.2 on Centos7 host. |
Priority: |
High |
Reporter: |
I use geoserver to publish WMS layers that will be consumed by a web app through OpenLayer v6. I enabled the CORS by uncommenting the corresponding First I loaded the WMS using the basic tileLoader of openLayer which consists of passing the WMS request URL to the Here is an exemple of an http request that will have a response with the CORS headers twice : Unable to find source-code formatter for language: txt. Available languages are: actionscript, ada, applescript, bash, c, c#, c++, cpp, css, erlang, go, groovy, haskell, html, java, javascript, js, json, lua, none, nyan, objc, perl, php, python, r, rainbow, ruby, scala, sh, sql, swift, visualbasic, xml, yaml
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100114-sha1:9fc4561) |
