[Geoserver-devel] [JIRA] (GEOS-9419) Adding SQL views via REST fails with JSON payload
Fadi created an issue
GeoServer / BugGEOS-9419
Issue Type:
BugBug
Affects Versions:
2.15.2, 2.16.0
Assignee:
Unassigned
Created:
28/Nov/19 4:51 PM
Priority:
MediumMedium
Reporter:
Fadi
Creating a SQL view-based layer via REST with the following request:
curl -i --user admin:geoserver -X POST -H ‘Content-Type: application/json; charset=utf-8’ -d @test_post.json
http://localhost:{port}/geoserver/rest/workspaces/{test_workspace}/datastores/{test_store}/featuretypes’
according to the documentation for Post-request
and the content of test_post.json as following:
  "featureType": {
    "name": "test_post",
    "title": "test_post",
    "metadata": {
      "entry": {
        "key": "JDBC_VIRTUAL_TABLE",
        "virtualTable": {
          "sql": "select id, area, 'test' AS test from test"
returns HTTP/1.1 500 server error
Schema ‘test_post’ does not exist
Noticed : omitting the “name” attribute from featureType turns the error into Schema ‘null’ does not exist
This works fine with XML, using the same with test_post.xml
curl -i --user admin:geoserver -X POST -H ‘Content-Type: text/xml; charset=utf-8’ -d @test_post.xml
test_post.xml :
<featureType>
    <name>test_post</name>
    <title>test_post</title>
    <metadata>
        <entry key="JDBC_VIRTUAL_TABLE">
            <virtualTable>
                <sql>
                </sql>
            </virtualTable>
        </entry>
    </metadata>
</featureType>
–> HTTP/1.1 201 Created
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100114-sha1:654add4)
Atlassian logo
