[Geoserver-devel] [JIRA] (GEOS-9447) NPE in Monitor (core) extension
lorenzo.pini created an issue
GeoServer / BugGEOS-9447
Issue Type:
BugBug
Affects Versions:
2.16.0, 2.17-RC
Assignee:
Unassigned
Components:
Monitoring
Created:
09/Jan/20 2:53 PM
Priority:
MediumMedium
Reporter:
lorenzo.pini
Monitoring extension logs a NullPointerException when the following URL is hit:
http://localhost:8080/geoserver/rest/
Notice the “/” on the end.
Without the slash, no error is logged:
Other REST URLs do not suffer from this issue, for example “http://localhost:8080/geoserver/rest/resource/” works correctly
If the audit file is enabled, all the requests (even the one causing the NPE) are logged in the audit log file.
Here is the log:
09 gen 14:41:26 ERROR [geoserver.rest] - -1
java.lang.ArrayIndexOutOfBoundsException: -1
        at org.geoserver.monitor.rest.RESTMonitorCallback.init(RESTMonitorCallback.java:44)
        at org.geoserver.rest.CallbackInterceptor.preHandle(CallbackInterceptor.java:32)
        at org.springframework.web.servlet.HandlerExecutionChain.applyPreHandle(HandlerExecutionChain.java:136)
        at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1033)
        at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:942)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:998)
        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:890)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
        at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:875)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
        at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:873)
        at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1623)
        at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26)
        at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1610)
        at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69)
        at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:73)
        at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66)
        at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:142)
        at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
        at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:37)
        at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320)
        at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:70)
        at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
        at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
        at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74)
        at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
        at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
        at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:119)
        at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:51)
        at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:215)
        at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
        at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81)
        at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
        at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
        at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)
        at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)
        at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
        at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:357)
        at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:270)
        at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:101)
        at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:79)
        at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
        at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
        at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
        at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:200)
        at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1602)
        at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:540)
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146)
        at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
        at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
        at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257)
        at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1700)
        at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255)
        at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1345)
        at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203)
        at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:480)
        at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1667)
        at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201)
        at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1247)
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144)
        at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:220)
        at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:152)
        at org.eclipse.jetty.server.Server.handle(Server.java:505)
        at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:370)
        at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:267)
        at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305)
        at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
        at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333)
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310)
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168)
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126)
        at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366)
        at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:698)
        at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:804)
        at java.lang.Thread.run(Thread.java:748)
09 gen 14:41:26 WARN [annotation.ExceptionHandlerExceptionResolver] - Resolved [java.lang.ArrayIndexOutOfBoundsException: -1]
To reproduce:
Expected result:
  • The “Geoserver Configuration API” page
Actual result:
  • “-1” and an error in the log
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100118-sha1:cb8103a)
Atlassian logo
