[Geoserver-devel] [JIRA] (GEOS-9463) Windows random failures in security subsystem
Andrea Aime created an issue
GeoServer / BugGEOS-9463
Issue Type:
BugBug
Assignee:
Unassigned
Components:
Security
Created:
23/Jan/20 2:41 PM
Priority:
MediumMedium
Reporter:
Andrea Aime
Tracking the traces for later:
2020-01-23T11:00:16.3235299Z [ERROR] Tests run: 7, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 11.553 s <<< FAILURE! - in org.geoserver.security.web.user.NewUserPageTest
2020-01-23T11:00:16.3685983Z [ERROR] testFill3(org.geoserver.security.web.user.NewUserPageTest) Time elapsed: 0.666 s <<< ERROR!
2020-01-23T11:00:16.3885772Z java.io.IOException: java.io.IOException: Failed to move D:\a\geoserver\geoserver\src\web\security\core\.\target\default962438681885083180data\security\usergroup\test\users.xml.7eb4415c-ce34-4245-99c0-c3b3eb4b4f2d.tmp - unable to remove existing: D:\a\geoserver\geoserver\src\web\security\core\target\default962438681885083180data\security\usergroup\test\users.xml
2020-01-23T11:00:16.4648623Z at org.geoserver.security.web.user.NewUserPageTest.doTestFill3(NewUserPageTest.java:109)
2020-01-23T11:00:16.5001958Z at org.geoserver.security.web.user.NewUserPageTest.testFill3(NewUserPageTest.java:105)
2020-01-23T11:00:16.5098071Z Caused by: java.io.IOException: Failed to move D:\a\geoserver\geoserver\src\web\security\core\.\target\default962438681885083180data\security\usergroup\test\users.xml.7eb4415c-ce34-4245-99c0-c3b3eb4b4f2d.tmp - unable to remove existing: D:\a\geoserver\geoserver\src\web\security\core\target\default962438681885083180data\security\usergroup\test\users.xml
2020-01-23T11:00:16.5460149Z at org.geoserver.security.web.user.NewUserPageTest.doTestFill3(NewUserPageTest.java:109)
and
[00:23:26] [ERROR] Tests run: 6, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 7.21 s <<< FAILURE! - in org.geoserver.security.web.role.RoleListPageTest
[00:23:26] [ERROR] testEdit(org.geoserver.security.web.role.RoleListPageTest) Time elapsed: 0.062 s <<< ERROR!
[00:23:26] java.io.IOException: java.io.IOException: Failed to move C:\projects\geoserver\src\web\security\core\.\target\default450977178552923229data\security\role\test\roles.xml.05f75ee3-9ff3-4663-b170-f15f061b0755.tmp - unable to remove existing: C:\projects\geoserver\src\web\security\core\target\default450977178552923229data\security\role\test\roles.xml
[00:23:26] Caused by: java.io.IOException: Failed to move C:\projects\geoserver\src\web\security\core\.\target\default450977178552923229data\security\role\test\roles.xml.05f75ee3-9ff3-4663-b170-f15f061b0755.tmp - unable to remove existing: C:\projects\geoserver\src\web\security\core\target\default450977178552923229data\security\role\test\roles.xml
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100118-sha1:cd103a2)
Atlassian logo
