[Geoserver-devel] [JIRA] (GEOS-9493) WFS GeoJSON complex features output issue on numeric typed xml attributes
Fernando Miño created an issue
GeoServer / BugGEOS-9493
Issue Type:
BugBug
Affects Versions:
2.16.0
Assignee:
Fernando Miño
Components:
Application schema
Created:
10/Feb/20 5:46 PM
Priority:
MediumMedium
Reporter:
Fernando Miño
When GeoJSON encoder tries to handle an xml attribute with other type than string, in this case an integer, Geoserver throws a class cast exception due to complex GeoJSON writer is handling all xml attributes as string. On GML output this issue is not present and numeric typed attributes are encoded without exceptions.
This was reproduced using a app-schema jdbc multi value element with an integer typed attribute and executing a WFS GetFeature requesting GeoJSON output.
https://docs.geoserver.org/stable/en/user/data/app-schema/mapping-file.html#attributes-with-cardinality-1-n
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100119-sha1:6c3d6e9)
Atlassian logo
