[Geoserver-devel] [JIRA] (GEOS-9494) SQL server data store requires a port to be provided but doesn't enforce it
Nuno Oliveira created an issue
GeoServer / BugGEOS-9494
SQL server data store requires a port to be provided but doesn’t enforce it
Issue Type:
BugBug
Assignee:
Unassigned
Created:
10/Feb/20 11:16 PM
Priority:
MediumMedium
Reporter:
Nuno Oliveira
The SQL server extension doesn’t require a connection port to be provided and don’t assume any default. If no connection port is provided the data store connection will fail with:
Caused by: java.lang.NullPointerException: Could not acquire data access 'dyreposisjoner',
        at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:606),
        ... 131 more,
The connection port mandatory should be mandatory on the UI configuration page and the default port 1433 should be used.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100119-sha1:6c3d6e9)
Atlassian logo
