[Geoserver-devel] [JIRA] (GEOS-9509) Incorrect handling of date type when inserting via WFS
Mitchell Bösecke created an issue
GeoServer / BugGEOS-9509
Issue Type:
BugBug
Affects Versions:
2.15.3
Assignee:
Unassigned
Components:
WFS
Created:
19/Feb/20 6:41 PM
Priority:
MediumMedium
Reporter:
Mitchell Bösecke
Using WFS, I insert a new record with a desired date of “2020-02-19” but it persists “2020-02-18” into the database.
My column is in a postgresql database and is of type “date”. My database and OS are configured to use the MST timezone (-7).
Sending any of these values to geoserver via WFS results in the undesired outcome:
  1. 2020-02-19T00:00:00.000-07:00
  2. 2020-02-19T07:00:00.000Z
  3. 2020-02-19
Applying “org.geotools.localDateTimeHandling” does not resolve or even change the outcome. I can confirm the hint is being applied properly because a GetFeatureInfo request changes it’s response from “2020-02-18Z” to “2020-02-18”. It almost appears to affect reading data but not writing data.
If I use the type “timestamp without time zone” in my postgresql database, I get the expected/desired outcome, i.e. it works correctly.
If I was to guess as to what’s happening, I suspect the the input date “2020-02-19T07:00:00.000Z” first gets truncated (because the database column doesn’t store a time) to “2020-02-19” and then it undergoes a UTC->MST conversion, ultimately becoming “2020-02-18”. If it converted the timezone FIRST and then removed the time, I suspect it would have the desired outcome.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100121-sha1:96a3924)
Atlassian logo
