[Geoserver-devel] [JIRA] (GEOS-9518) JDBCConfig fails to import data dir with NPE
Andrea Aime created an issue
GeoServer / BugGEOS-9518
Issue Type:
BugBug
Assignee:
Unassigned
Components:
Community modules
Created:
27/Feb/20 5:18 PM
Priority:
MediumMedium
Reporter:
Andrea Aime
I tried to import again a data dir I’m keeping for testing, has 1000 workspaces and over 40k layers… used to import, now it fails during the startup with the following log:
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'advertisedCatalog' defined in URL [jar:file:/home/aaime/devel/cluster-tests/geoserver-2.17-SNAPSHOT-jdbc1/webapps/geoserver/WEB-INF/lib/gs-main-2.17-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean 'secureCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/aaime/devel/cluster-tests/geoserver-2.17-SNAPSHOT-jdbc1/webapps/geoserver/WEB-INF/lib/gs-main-2.17-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/aaime/devel/cluster-tests/geoserver-2.17-SNAPSHOT-jdbc1/webapps/geoserver/WEB-INF/lib/gs-main-2.17-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.reflect.UndeclaredThrowableException
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:314)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:110)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:676)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:188)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1340)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1186)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:555)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:515)
at org.springframework.beans.factory.support.AbstractBeanFactory.lambda$doGetBean$0(AbstractBeanFactory.java:320)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:318)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:199)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:303)
... 84 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'accessRulesDao' defined in URL [jar:file:/home/aaime/devel/cluster-tests/geoserver-2.17-SNAPSHOT-jdbc1/webapps/geoserver/WEB-INF/lib/gs-main-2.17-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'rawCatalog' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/aaime/devel/cluster-tests/geoserver-2.17-SNAPSHOT-jdbc1/webapps/geoserver/WEB-INF/lib/gs-main-2.17-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.reflect.UndeclaredThrowableException
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:307)
... 96 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [jar:file:/home/aaime/devel/cluster-tests/geoserver-2.17-SNAPSHOT-jdbc1/webapps/geoserver/WEB-INF/lib/gs-main-2.17-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.reflect.UndeclaredThrowableException
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:601)
... 110 more
Caused by: java.lang.RuntimeException: java.lang.reflect.UndeclaredThrowableException
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:266)
at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitialization(GeoServerLoaderProxy.java:57)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:414)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1763)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:593)
... 116 more
Caused by: java.lang.reflect.UndeclaredThrowableException
at com.sun.proxy.$Proxy28.syncTo(Unknown Source)
at org.geoserver.catalog.impl.CatalogImpl.sync(CatalogImpl.java:1989)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:400)
at org.geoserver.jdbcconfig.JDBCGeoServerLoader.loadCatalogInternal(JDBCGeoServerLoader.java:91)
at org.geoserver.jdbcconfig.JDBCGeoServerLoader.loadCatalog(JDBCGeoServerLoader.java:78)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:261)
... 120 more
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.geoserver.catalog.LockingCatalogFacade.invoke(LockingCatalogFacade.java:36)
... 126 more
Caused by: java.lang.NullPointerException
at org.geoserver.jdbcconfig.internal.ConfigDatabase.lookUpRelatedObject(ConfigDatabase.java:714)
at org.geoserver.jdbcconfig.internal.ConfigDatabase.addAttribute(ConfigDatabase.java:603)
at org.geoserver.jdbcconfig.internal.ConfigDatabase.addAttributes(ConfigDatabase.java:579)
at org.geoserver.jdbcconfig.internal.ConfigDatabase.add(ConfigDatabase.java:548)
at org.geoserver.jdbcconfig.internal.ConfigDatabase$$FastClassBySpringCGLIB$$dd464281.invoke(<generated>)
at org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:218)
at org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:750)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163)
at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:295)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:98)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
at org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:689)
at org.geoserver.jdbcconfig.internal.ConfigDatabase$$EnhancerBySpringCGLIB$$f602b7d0.add(<generated>)
at org.geoserver.jdbcconfig.catalog.JDBCCatalogFacade.addInternal(JDBCCatalogFacade.java:902)
at org.geoserver.jdbcconfig.catalog.JDBCCatalogFacade.add(JDBCCatalogFacade.java:297)
at org.geoserver.catalog.impl.DefaultCatalogFacade.syncTo(DefaultCatalogFacade.java:991)
at org.geoserver.catalog.impl.IsolatedCatalogFacade.syncTo(IsolatedCatalogFacade.java:471)
The code in question seems to turn a non null list of values into a null value, and then goes “boom” trying to get a class out of it. But I could not debug exactly what’s the dangling reference about. If anyone is interested I have the (massive) data dir available.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100121-sha1:0fbe7c1)
Atlassian logo
