[Geoserver-devel] [JIRA] (GEOS-9532) JDBCConfig import - insufficient logging with reference issues
Niels Charlier created an issue
GeoServer / BugGEOS-9532
Issue Type:
BugBug
Assignee:
Unassigned
Created:
07/Mar/20 9:55 AM
Priority:
MediumMedium
Reporter:
Niels Charlier
JDBCConfig import fails when you have a layer that refers to a style that doesn’t exist (any more).
Technically, that means there is a fault in your data directory, however, the objects that cause the problem should be mentioned in the logs by name so that the user can fix the issue in his data directory, without needing to use a debugger to find out what is causing the problem.
Caused by: org.springframework.dao.EmptyResultDataAccessException: Incorrect result size: expected 1, actual 0
at org.springframework.dao.support.DataAccessUtils.nullableSingleResult(DataAccessUtils.java:97)
at org.springframework.jdbc.core.namedparam.NamedParameterJdbcTemplate.queryForObject(NamedParameterJdbcTemplate.java:233)
at org.springframework.jdbc.core.namedparam.NamedParameterJdbcTemplate.queryForObject(NamedParameterJdbcTemplate.java:241)
at org.springframework.jdbc.core.namedparam.NamedParameterJdbcTemplate.queryForObject(NamedParameterJdbcTemplate.java:257)
at org.geoserver.jdbcconfig.internal.ConfigDatabase.findObjectId(ConfigDatabase.java:879)
at org.geoserver.jdbcconfig.internal.ConfigDatabase.addAttribute(ConfigDatabase.java:598)
at org.geoserver.jdbcconfig.internal.ConfigDatabase.addAttributes(ConfigDatabase.java:566)
at org.geoserver.jdbcconfig.internal.ConfigDatabase.add(ConfigDatabase.java:535)
at org.geoserver.jdbcconfig.internal.ConfigDatabase$$FastClassBySpringCGLIB$$dd464281.invoke(<generated>)
at org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:218)
at org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:746)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163)
at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:294)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:98)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
at org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:688)
at org.geoserver.jdbcconfig.internal.ConfigDatabase$$EnhancerBySpringCGLIB$$46c3140d.add(<generated>)
at org.geoserver.jdbcconfig.catalog.JDBCCatalogFacade.addInternal(JDBCCatalogFacade.java:908)
at org.geoserver.jdbcconfig.catalog.JDBCCatalogFacade.add(JDBCCatalogFacade.java:297)
at org.geoserver.catalog.impl.DefaultCatalogFacade.syncTo(DefaultCatalogFacade.java:991)
at org.geoserver.catalog.impl.IsolatedCatalogFacade.syncTo(IsolatedCatalogFacade.java:471)
… 73 more
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100121-sha1:b4d24b6)
Atlassian logo
