lorenzo.pini created an issue |
Jiffle Rendering Transformation causes bad rendering on reprojection to 3995 |
Issue Type: |
Bug |
Affects Versions: |
2.16.1, 2.18-RC |
Assignee: |
Unassigned |
Attachments: |
S-OSI_-FRA_-MTOP-GLBSST_FIELD-202002261200Z.nc, bad.png, good.png, jiffle.sld |
Components: |
WMS, WPS |
Created: |
26/Mar/20 12:09 AM |
Priority: |
Medium |
Reporter: |
I’m using the Jiffle rendering transformation to remove some pixels, and the result is then reprojected from 4326 to 3995. The result of the reprojection with a style that uses the map algebra is different from the result of the reprojection without the map algebra. It looks like the resolution got lower. Here is how it looks without the map algebra: Here is how it looks with the map algebra: In a multiband NetCDF file (attached) one band is used to decide whether or not render pixels from another band.
A colormap is then applied; the full style is attached. To reproduce:
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100122-sha1:092c6a7) |
