2020-04-02T17:34:53.7193240Z [INFO] Running org.geoserver.wps.gs.RangeLookupTest
2020-04-02T17:34:56.6895020Z [ERROR] Tests run: 6, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 9.683 s <<< FAILURE! - in org.geoserver.gwc.ConfigurableBlobStoreTest
2020-04-02T17:34:56.6898470Z [ERROR] testTileDeleteByParameters(org.geoserver.gwc.ConfigurableBlobStoreTest) Time elapsed: 0.026 s <<< ERROR!
2020-04-02T17:34:56.6898820Z java.io.IOException: Unable to delete directory ./target/default2463070034800619985data/testConfigurableBlobStore/*gwc_in_progress_deletes*/test_123123_112_EPSG_4326_07_8589ce08ed730e1e6135880129469da574b4fd01/00_00.
2020-04-02T17:34:56.6899400Z at org.geoserver.gwc.ConfigurableBlobStoreTest.after(ConfigurableBlobStoreTest.java:102)
2020-04-02T17:34:56.6899550Z
2020-04-02T17:34:56.6900580Z [ERROR] testTileDeleteByParametersId(org.geoserver.gwc.ConfigurableBlobStoreTest) Time elapsed: 0.013 s <<< ERROR!
2020-04-02T17:34:56.6904700Z java.io.IOException: Unable to delete directory ./target/default2463070034800619985data/testConfigurableBlobStore/*gwc_in_progress_deletes*/test_123123_112_EPSG_4326_07_8589ce08ed730e1e6135880129469da574b4fd01/00_00.
2020-04-02T17:34:56.6905670Z at org.geoserver.gwc.ConfigurableBlobStoreTest.after(ConfigurableBlobStoreTest.java:102)
2020-04-02T17:34:56.6906030Z
This seems due to timings, the mass delete operations in blobstore return immediately but enact the removal in a background thread.
