[Geoserver-devel] [JIRA] (GEOS-9567) [Backup/Restore] Rest Controller not able to backup secured resources
Alessio Fabiani created an issue
GeoServer / BugGEOS-9567
Issue Type:
BugBug
Affects Versions:
2.15.5, 2.16.2, 2.17-RC
Assignee:
Alessio Fabiani
Components:
Backup and Restore
Created:
07/Apr/20 11:28 PM
Fix Versions:
2.15.6, 2.16.3, 2.17.0, 2.18-RC
Priority:
MediumMedium
Reporter:
Alessio Fabiani
Trying to perform a backup of a GeoServer catalog having protected resources through the REST APIs fails with the following exception:
2020-04-06 11:07:51,553 DEBUG [backuprestore.listener] - Executions Step Summaries : {7=StepExecution: id=7, version=2, name=backupResourceInfos, status=FAILED, exitStatus=FAILED, readCount=0, filterCount=0, writeCount=0 readSkipCount=0, writeSkipCount=0, processSkipCount=0, commitCount=0, rollbackCount=1, exitDescription=org.geoserver.catalog.CatalogException: java.lang.Exception: Not all the Catalog Resources of class [interface org.geoserver.catalog.ResourceInfo] have been dumped!
at org.geoserver.backuprestore.BackupRestoreItem.logValidationExceptions(BackupRestoreItem.java:307)
at org.geoserver.backuprestore.reader.CatalogItemReader.doRead(CatalogItemReader.java:64)
at org.geoserver.backuprestore.reader.CatalogReader.read(CatalogReader.java:130)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:343)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:198)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:136)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:124)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:212)
at com.sun.proxy.$Proxy100.read(Unknown Source)
at org.springframework.batch.core.step.item.SimpleChunkProvider.doRead(SimpleChunkProvider.java:91)
at org.springframework.batch.core.step.item.SimpleChunkProvider.read(SimpleChunkProvider.java:157)
at org.springframework.batch.core.step.item.SimpleChunkProvider$1.doInIteration(SimpleChunkProvider.java:116)
at org.springframework.batch.repeat.support.RepeatTemplate.getNextResult(RepeatTemplate.java:374)
at org.springframework.batch.repeat.support.RepeatTemplate.executeInternal(RepeatTemplate.java:215)
at org.springframework.batch.repeat.support.RepeatTemplate.iterate(RepeatTemplate.java:144)
at org.springframework.batch.core.step.item.SimpleChunkProvider.provide(SimpleChunkProvider.java:110)
at org.springframework.batch.core.step.item.ChunkOrientedTasklet.execute(ChunkOrientedTasklet.java:69)
at org.springframework.batch.core.step.tasklet.TaskletStep$ChunkTransactionCallback.doInTransaction(TaskletStep.java:406)
at org.springframework.batch.core.step.tasklet.TaskletStep$ChunkTransactionCallback.doInTransaction(TaskletStep.java:330)
at org.springframework.transaction.support.TransactionTemplate.execute(TransactionTemplate.java:140)
at org.springframework.batch.core.step.tasklet.TaskletStep$2.doInChunkContext(TaskletStep.java:271)
at org.springframework.batch.core.scope.context.StepContextRepeatCallback.doInIteration(StepContextRepeatCallback.java:81)
at org.springframework.batch.core.step.tasklet.TaskletStep.doExecute(TaskletStep.java:257)
at org.springframework.batch.core.step.AbstractStep.execute(AbstractStep.java:200)
at org.springframework.batch.core.job.SimpleStepHandler.handleStep(SimpleStepHandler.java:148)
at org.springframework.batch.core.job.flow.JobFlowExecutor.executeStep(JobFlowExecutor.java:64)
at org.springframework.batch.core.job.flow.support.state.StepState.handle(StepState.java:67)
at org.springframework.batch.core.job.flow.support.SimpleFlow.resume(SimpleFlow.java:169)
at org.springframework.batch.core.job.flow.support.SimpleFlow.start(SimpleFlow.java:144)
at org.springframework.batch.core.job.flow.FlowJob.doExecute(FlowJob.java:134)
at org.springframework.batch.core.job.AbstractJob.execute(AbstractJob.java:306)
at org.springframework.batch.core.launch.support.SimpleJobLauncher$1.run(SimpleJobLauncher.java:135)
at org.springframework.core.task.SimpleAsyncTaskExecutor$ConcurrencyThrottlingRunnable.run(SimpleAsyncTaskExecutor.java:275)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.Exception: Not all the Catalog Resources of class [interface org.geoserver.catalog.ResourceInfo] have been dumped!
at org.geoserver.backuprestore.reader.CatalogItemReader.doRead(CatalogItemReader.java:58)
... 41 more
The issue is caused by the CatalogItemReader trying to dump the ResourceInfos present in the Catalog.
Authentication is not passed to the Facade() causing the reader to fail to fetch the protected resources.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100124-sha1:c13ca0d)
Atlassian logo
