Tom Saul created an issue |
Issue Type: |
Bug |
Affects Versions: |
2.17.0 |
Assignee: |
Unassigned |
Created: |
15/May/20 2:06 AM |
Environment: |
Windows Server |
Priority: |
Low |
Reporter: |
The tomcat instance will not start if you include the ‘-XX:+UseStringDeduplicationJVM’ startup parameter (it is not valid for this java release). This option is recommended in the setup docs at https://docs.geoserver.org/stable/en/user/production/container.html The documentation should likely be updated to reflect that it is only usable on earlier Java versions . |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100126-sha1:acdbdcc) |
