[Geoserver-devel] [JIRA] (GEOS-9622) NullPointerException when using WMS vendor parameter "CLIP" on an ImageMosaic based layer
Michael Bauer created an issue
GeoServer / BugGEOS-9622
NullPointerException when using WMS vendor parameter “CLIP” on an ImageMosaic based layer
Issue Type:
BugBug
Affects Versions:
2.17.0
Assignee:
Unassigned
Geoserver_ImageMosaik_NPE.log
Components:
image mosaic, WMS
Created:
15/May/20 2:59 PM
Environment:
Geoserver 2.17.0 (.war file), Java 11 (AdoptOpenJDK), Tomcat 8.5.38, Windows 11 (same behaviour on Linux 18.0.4)
Priority:
MediumMedium
Reporter:
Michael Bauer
Hi Geoserver Team,
I’m referring to my user list post (https://sourceforge.net/p/geoserver/mailman/message/37004708/).
I was also able to reproduce the NPE with the provided sample data and configuration in the Geoserver data directory so I think it is a bug in the current version 2.17.0 of Geoserver and I would like to report it to you. (If it is no bug I’m sorry for bothering you)
How to reproduce the NullPointerException:
Further descripton:
  • The first WMS request with ‘clip’ parameter works as expected
  • The second request causes the NPE (see attachment)
  • After the second request it is not possible anymore to request the layer, you have to restart the Tomcat server or reload the data dir cofiguration.
  • It makes no difference if I use a Shapefile or database configuration for the datastore
Best regards
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100126-sha1:acdbdcc)
Atlassian logo
