Encountered with last jetty:9-jre8 docker image with a GeoServer 2.17:
2020-07-20 09:15:23.577:WARN:oejw.WebAppContext:main: Failed startup of context o.e.j.w.WebAppContext@anonymised.com{GeoServer,/geoserver,file:///var/lib/jetty/webapps/geoserver/,UNAVAILABLE}{/var/lib/jetty/webapps/geoserver}
org.springframework.beans.factory.BeanCreationException: Error occured reading security configuration; nested exception is java.lang.RuntimeException: org.jasypt.exceptions.EncryptionInitializationException: java.lang.NoClassDefFoundError: Could not initialize class com.ibm.icu.impl.ICUDebug
at org.geoserver.security.GeoServerSecurityManager.reload(GeoServerSecurityManager.java:432)
Caused by:
at org.geoserver.security.GeoServerSecurityManager.getMasterPassword(GeoServerSecurityManager.java:1765)
Caused by:
at org.jasypt.encryption.pbe.StandardPBEByteEncryptor.initialize(StandardPBEByteEncryptor.java:716)
Caused by:
at com.ibm.icu.impl.NormalizerDataReader.<clinit>(NormalizerDataReader.java:300)
Using the following Java class indeed fails:
% cat TestClass.java
class TestClass {
public static void main(String[] args) {
try {
Class.forName("com.ibm.icu.impl.ICUDebug");
System.out.println("it works");
} catch (ClassNotFoundException e) {
System.err.println("Class not found");
% java -cp /var/lib/jetty/webapps/geoserver/WEB-INF/lib/icu4j-3.4.4.jar:. TestClass
Exception in thread "main" java.lang.ExceptionInInitializerError
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at TestClass.main(TestClass.java:6)
Caused by: java.lang.IllegalArgumentException: Invalid version number: Version number may be negative or greater than 255
at com.ibm.icu.util.VersionInfo.getInstance(VersionInfo.java:188)
at com.ibm.icu.impl.ICUDebug.getInstanceLenient(ICUDebug.java:65)
at com.ibm.icu.impl.ICUDebug.<clinit>(ICUDebug.java:69)
... 3 more
Here is the Java version used:
% java -version
openjdk version "1.8.0_262"
OpenJDK Runtime Environment (build 1.8.0_262-b10)
OpenJDK 64-Bit Server VM (build 25.262-b10, mixed mode)
Here is a redhat (requires to log in) related issue: https://access.redhat.com/solutions/5026361 which recommends to downgrade to a build < 255.
Launching the same code snippet on a previous version of the Java runtime works:
it works
% java -version
openjdk version "1.8.0_252"
OpenJDK Runtime Environment (build 1.8.0_252-b09)
OpenJDK 64-Bit Server VM (build 25.252-b09, mixed mode)
