[Geoserver-devel] [JIRA] (GEOS-9715) export format does not presen OGR-GPX format
Eric Smets created an issue
GeoServer / BugGEOS-9715
Issue Type:
BugBug
Affects Versions:
2.17.1
Assignee:
Unassigned
Created:
12/Aug/20 12:40 PM
Environment:
linux debian tomcat8 gdal 2.4 + libgdal-java
Priority:
MediumMedium
Reporter:
Eric Smets
OGR-GPX and other formats are not seen as supprted formats
  • issue is that the jndi not found
    12-Aug-2020 12:13:53.652 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive /var/lib/tomcat8/webapps/geoserver.war
    12-Aug-2020 12:14:01.169 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
    Native library load failed.
    java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
    12-Aug-2020 12:14:02.087 INFO [localhost-startStop-1] it.geosolutions.imageio.gdalframework.GDALUtilities.loadGDAL GDAL Native Library loaded (version: 2.4.0)
    12-Aug-2020 12:14:02.699 WARNING [localhost-startStop-1] org.geoserver.platform.GeoServerExtensions.checkContext Extension lookup ‘XStreamPersisterInitializer’, but ApplicationContext is unset.
    12-Aug-2020 12:14:02.700 WARNING [localhost-startStop-1] org.geoserver.platform.GeoServerExtensions.checkContext Extension lookup ‘ExtensionFilter’, but ApplicationContext is unset.
    12-Aug-2020 12:14:02.702 WARNING [localhost-startStop-1] org.geoserver.platform.GeoServerExtensions.checkContext Extension lookup ‘ExtensionProvider’, but ApplicationContext is unset.
    12-Aug-2020 12:14:02.702 WARNING [localhost-startStop-1] org.geoserver.platform.GeoServerExtensions.checkContext Extension lookup ‘ExtensionFilter’, but ApplicationContext is unset.
    log4j:WARN File option not set for appender [geoserverlogfile].
    log4j:WARN Are you using FileAppender instead of ConsoleAppender?
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100144-sha1:57e1ab7)
Atlassian logo
