Imran Rajjad created an issue |
CRS Panel (Resource Config GUI) overrides URN SRS format with EPSG:XXXX format |
Issue Type: |
Bug |
Assignee: |
Attachments: |
image-2020-10-02-21-32-42-850.png, image-2020-10-02-21-33-12-896.png |
Components: |
web |
Created: |
02/Oct/20 6:42 PM |
Fix Versions: |
2.18-RC |
Priority: |
Medium |
Reporter: |
Consider the below Remote WFS Layer with additional native SRS. One of the SRS is in URN OGC format. (urn:ogc:def:crs:EPSG::4326) <FeatureType xmlns:topp=“http://www.topp.com”> Steps to reproduce Configure layer with URN OGC SRS Save the layer, and open map preview, the layer seems to be rendering fine Open the Layer page to Edit The GUI page depends upon the Text fields to generate the CRS object for catalog persistence, the URN OGC is lost after page is saved or revisited for editing. EPSG and URN OGC representations of same code can have different Axis orders, hence this will cause issues ( 4326 is a common case). The problem is at CRSPanel.toSRS function, which blindly converts a CRS object into EPSG code. A fix is proposed to update the CRSPanel class to accept a boolean flag, which will ensure the text field for SRS will always chose the string literal from SRS Provider items. This will allow to keep other representations of SRS intact. |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100148-sha1:d3a00c3) |
