Capabilities_1_3_0_Transformer :
private void doHandleLayer(LayerInfo layer, boolean isRoot) {
try {
mark();
handleLayer(layer, isRoot);
commit();
} catch (Exception e) {
// report what layer we failed on to help the admin locate and fix it
if (skipping) {
LOGGER.log(
Level.WARNING,
"Error writing metadata; skipping layer: " + layer.getName(),
e);
reset();
} else {
throw new ServiceException(
"Error occurred trying to write out metadata for layer: "
+ layer.getName(),
e);
org.geotools.xml.transform.TransformerBase$TranslatorSupport.commit() is shadowing the ClientStreamAbortedException with a RuntimeException , which the getcapabilites translator should check for anyways.
Reproduce: have a thousand layers, query wms capabilities with curl, hit CTRL+C, and get a thousand of these exceptions in the logs.
2020-10-08 03:08:57.318 WARN 1674703 --- [nio-9102-exec-3] org.geoserver.wms.capabilities : Error writing metadata; skipping layer: tasmania_roadstoppcopy-291
java.lang.RuntimeException: Error while committing XML elements; specific element was: Start(Layer, org.xml.sax.helpers.AttributesImpl@anonymised.com)
at org.geotools.xml.transform.TransformerBase$TranslatorSupport.commit(TransformerBase.java:697) ~[gt-xml-25-SNAPSHOT.jar:na]
at org.geoserver.wms.capabilities.GetCapabilitiesTransformer$CapabilitiesTranslator.handleLayerTree(GetCapabilitiesTransformer.java:948) ~[gs-wms-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.geoserver.wms.capabilities.GetCapabilitiesTransformer$CapabilitiesTranslator.handleLayers(GetCapabilitiesTransformer.java:722) ~[gs-wms-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.geoserver.wms.capabilities.GetCapabilitiesTransformer$CapabilitiesTranslator.handleCapability(GetCapabilitiesTransformer.java:480) ~[gs-wms-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.geoserver.wms.capabilities.GetCapabilitiesTransformer$CapabilitiesTranslator.encode(GetCapabilitiesTransformer.java:334) ~[gs-wms-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:990) ~[gt-xml-25-SNAPSHOT.jar:na]
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:485) ~[xalan-2.7.2.jar:na]
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:283) ~[gt-xml-25-SNAPSHOT.jar:na]
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:118) ~[gt-xml-25-SNAPSHOT.jar:na]
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:100) ~[gt-xml-25-SNAPSHOT.jar:na]
at org.geoserver.wms.capabilities.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:104) ~[gs-wms-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.geoserver.config.CapabilitiesCacheHeadersCallback$RevalidateTagResponse.write(CapabilitiesCacheHeadersCallback.java:133) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:1030) ~[gs-ows-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:269) ~[gs-ows-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177) ~[spring-webmvc-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at org.geoserver.cloud.wms.WMSController.handle(WMSController.java:50) ~[classes/:na]
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:na]
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:na]
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:na]
at java.base/java.lang.reflect.Method.invoke(Method.java:566) ~[na:na]
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:190) ~[spring-web-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:138) ~[spring-web-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:105) ~[spring-webmvc-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:878) ~[spring-webmvc-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:792) ~[spring-webmvc-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87) ~[spring-webmvc-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1040) ~[spring-webmvc-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:943) ~[spring-webmvc-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006) ~[spring-webmvc-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:898) ~[spring-webmvc-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:645) ~[javax.servlet-api-4.0.1.jar:4.0.1]
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883) ~[spring-webmvc-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:750) ~[javax.servlet-api-4.0.1.jar:4.0.1]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53) ~[tomcat-embed-websocket-9.0.37.jar:9.0.37]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320) ~[spring-security-web-5.3.4.RELEASE.jar:5.3.4.RELEASE]
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:70) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126) ~[spring-security-web-5.3.4.RELEASE.jar:5.3.4.RELEASE]
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90) ~[spring-security-web-5.3.4.RELEASE.jar:5.3.4.RELEASE]
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334) ~[spring-security-web-5.3.4.RELEASE.jar:5.3.4.RELEASE]
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:118) ~[spring-security-web-5.3.4.RELEASE.jar:5.3.4.RELEASE]
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:51) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:155) ~[spring-security-web-5.3.4.RELEASE.jar:5.3.4.RELEASE]
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119) ~[spring-web-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105) ~[spring-security-web-5.3.4.RELEASE.jar:5.3.4.RELEASE]
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215) ~[spring-security-web-5.3.4.RELEASE.jar:5.3.4.RELEASE]
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178) ~[spring-security-web-5.3.4.RELEASE.jar:5.3.4.RELEASE]
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70) ~[gs-wms-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:37) ~[gs-platform-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:103) ~[spring-web-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:100) ~[spring-web-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at org.springframework.web.filter.FormContentFilter.doFilterInternal(FormContentFilter.java:93) ~[spring-web-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at org.springframework.boot.actuate.metrics.web.servlet.WebMvcMetricsFilter.doFilterInternal(WebMvcMetricsFilter.java:93) ~[spring-boot-actuator-2.3.3.RELEASE.jar:2.3.3.RELEASE]
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201) ~[spring-web-5.2.8.RELEASE.jar:5.2.8.RELEASE]
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:202) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:541) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:139) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:373) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1589) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[na:na]
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[na:na]
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at java.base/java.lang.Thread.run(Thread.java:834) ~[na:na]
Caused by: java.lang.RuntimeException: org.xml.sax.SAXException: org.geoserver.ows.ClientStreamAbortedException
at org.geotools.xml.transform.TransformerBase$TranslatorSupport._start(TransformerBase.java:773) ~[gt-xml-25-SNAPSHOT.jar:na]
at org.geotools.xml.transform.TransformerBase$TranslatorSupport.access$000(TransformerBase.java:404) ~[gt-xml-25-SNAPSHOT.jar:na]
at org.geotools.xml.transform.TransformerBase$TranslatorSupport$Start.commit(TransformerBase.java:436) ~[gt-xml-25-SNAPSHOT.jar:na]
at org.geotools.xml.transform.TransformerBase$TranslatorSupport.commit(TransformerBase.java:693) ~[gt-xml-25-SNAPSHOT.jar:na]
... 122 common frames omitted
Caused by: org.xml.sax.SAXException: org.geoserver.ows.ClientStreamAbortedException
at org.apache.xml.serializer.ToStream.startElement(ToStream.java:1948) ~[serializer-2.7.2.jar:2.7.2]
at org.apache.xalan.transformer.TransformerIdentityImpl.startElement(TransformerIdentityImpl.java:1073) ~[xalan-2.7.2.jar:na]
at org.geotools.xml.transform.TransformerBase$TranslatorSupport._start(TransformerBase.java:771) ~[gt-xml-25-SNAPSHOT.jar:na]
... 125 common frames omitted
Caused by: org.geoserver.ows.ClientStreamAbortedException: null
at org.geoserver.ows.DispatcherOutputStream.write(DispatcherOutputStream.java:40) ~[gs-ows-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.apache.xml.serializer.WriterToUTF8Buffered.flushBuffer(WriterToUTF8Buffered.java:447) ~[serializer-2.7.2.jar:2.7.2]
at org.apache.xml.serializer.WriterToUTF8Buffered.write(WriterToUTF8Buffered.java:191) ~[serializer-2.7.2.jar:2.7.2]
at org.apache.xml.serializer.ToStream.outputLineSep(ToStream.java:381) ~[serializer-2.7.2.jar:2.7.2]
at org.apache.xml.serializer.ToStream.indent(ToStream.java:789) ~[serializer-2.7.2.jar:2.7.2]
at org.apache.xml.serializer.ToStream.indent(ToStream.java:805) ~[serializer-2.7.2.jar:2.7.2]
at org.apache.xml.serializer.ToStream.startElement(ToStream.java:1937) ~[serializer-2.7.2.jar:2.7.2]
... 127 common frames omitted
Caused by: org.apache.catalina.connector.ClientAbortException: java.io.IOException: Broken pipe
at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:351) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.catalina.connector.OutputBuffer.appendByteArray(OutputBuffer.java:746) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.catalina.connector.OutputBuffer.append(OutputBuffer.java:675) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.catalina.connector.OutputBuffer.writeBytes(OutputBuffer.java:386) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.catalina.connector.OutputBuffer.write(OutputBuffer.java:364) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.catalina.connector.CoyoteOutputStream.write(CoyoteOutputStream.java:96) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.geoserver.filters.FlushSafeResponse$FlushSafeServletOutputStream.write(FlushSafeResponse.java:57) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.springframework.security.web.util.OnCommittedResponseWrapper$SaveContextServletOutputStream.write(OnCommittedResponseWrapper.java:645) ~[spring-security-web-5.3.4.RELEASE.jar:5.3.4.RELEASE]
at java.base/java.io.ByteArrayOutputStream.writeTo(ByteArrayOutputStream.java:187) ~[na:na]
at org.vfny.geoserver.util.PartialBufferedOutputStream2.flushBuffer(PartialBufferedOutputStream2.java:152) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.vfny.geoserver.util.PartialBufferedOutputStream2.checkBuffer(PartialBufferedOutputStream2.java:146) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.vfny.geoserver.util.PartialBufferedOutputStream2.write(PartialBufferedOutputStream2.java:140) ~[gs-main-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
at org.geoserver.ows.DispatcherOutputStream.write(DispatcherOutputStream.java:38) ~[gs-ows-2.19-SNAPSHOT.jar:2.19-SNAPSHOT]
... 133 common frames omitted
Caused by: java.io.IOException: Broken pipe
at java.base/sun.nio.ch.FileDispatcherImpl.write0(Native Method) ~[na:na]
at java.base/sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47) ~[na:na]
at java.base/sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:113) ~[na:na]
at java.base/sun.nio.ch.IOUtil.write(IOUtil.java:79) ~[na:na]
at java.base/sun.nio.ch.IOUtil.write(IOUtil.java:50) ~[na:na]
at java.base/sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:466) ~[na:na]
at org.apache.tomcat.util.net.NioChannel.write(NioChannel.java:138) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.tomcat.util.net.NioBlockingSelector.write(NioBlockingSelector.java:101) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.tomcat.util.net.NioSelectorPool.write(NioSelectorPool.java:152) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.tomcat.util.net.NioEndpoint$NioSocketWrapper.doWrite(NioEndpoint.java:1252) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.tomcat.util.net.SocketWrapperBase.doWrite(SocketWrapperBase.java:764) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.tomcat.util.net.SocketWrapperBase.writeBlocking(SocketWrapperBase.java:584) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.tomcat.util.net.SocketWrapperBase.write(SocketWrapperBase.java:528) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.coyote.http11.Http11OutputBuffer$SocketOutputBuffer.doWrite(Http11OutputBuffer.java:538) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.coyote.http11.filters.ChunkedOutputFilter.doWrite(ChunkedOutputFilter.java:110) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.coyote.http11.Http11OutputBuffer.doWrite(Http11OutputBuffer.java:190) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.coyote.Response.doWrite(Response.java:601) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:339) ~[tomcat-embed-core-9.0.37.jar:9.0.37]
... 145 common frames omitted
