When trying to run WPS-Download community module example mentioned at this link
https://docs.geoserver.org/stable/en/user/community/wps-download/rawDownload.html#sample-request
got following error:
04 nov. 23:53:57 ERROR [wps.executor] - Process execution failed
org.geotools.process.ProcessException: java.lang.IllegalArgumentException: Argumento invalido: “type=null”.
at org.geoserver.wps.gs.download.DownloadProcess.execute(DownloadProcess.java:472)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:621)
at org.geoserver.wps.executor.ProcessStartupFilter$ProcessStartupWrapper.execute(ProcessStartupFilter.java:50)
at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:224)
at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:1)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
at java.base/java.lang.Thread.run(Thread.java:844)
Caused by: java.lang.IllegalArgumentException: Argumento invalido: “type=null”.
at org.geotools.coverage.TypeMap.map(TypeMap.java:404)
at org.geotools.coverage.TypeMap.getSize(TypeMap.java:350)
at org.geoserver.wps.gs.download.RasterEstimator.execute(RasterEstimator.java:220)
at org.geoserver.wps.gs.download.DownloadEstimatorProcess.execute(DownloadEstimatorProcess.java:188)
at org.geoserver.wps.gs.download.DownloadProcess.execute(DownloadProcess.java:299)
… 12 more
Based on debug, error is generated in line 220 at this file since coverageDimensionInfoList.get.getDimensionType() value is null, so then getSize() call fails.
Based on testing using default geoserver data_dir, it’s required to update the bands definitions on the raster files referenced by gs:Download, in order to make it work. For some reason, those values are not correct when trying to use the mentioned module (which attempts to calculate size based on that values)
