[Geoserver-devel] [JIRA] (GEOS-9788) Keycloak-plugin wrong role mapping
Paul Biskup created an issue
GeoServer / BugGEOS-9788
Issue Type:
BugBug
Affects Versions:
2.17.2
Assignee:
Unassigned
Components:
Community modules, Security
Created:
06/Nov/20 1:11 PM
Priority:
LowLow
Reporter:
Paul Biskup
This issue is referencing to this GeoServer-dev-mailing-list-post: http://osgeo-org.1560.x6.nabble.com/Keycloak-plugin-wrong-role-mapping-td5449169.html
I was trying to setup GeoServer using the Keycloak-authentication-plugin following this documentation: https://docs.geoserver.org/latest/en/user/community/keycloak/index.html
I was able to connect to my Keycloak and to set it up for the ADMINISTRATOR- and AUTHENTICATED-role, as described in the example.
But when I tried to use own Keycloak-roles it wasn’t working and I was facing the same problems as the user in this GeoServer-User-mailinglist-post: http://osgeo-org.1560.x6.nabble.com/Keycloak-Roles-td5427804.html
Running the GeoServer in debug-mode I found the problem, which is caused by the used authority-mapper-class, that is trying to map the rolenames from Keycloak against the rolenames in GeoServer:
org.springframework.security.core.authority.mapping.SimpleAuthorityMapper
This SimpleAuthorityMapper-class is setting the default prefix „ROLE_“ in front of every rolename coming from Keycloak:
public final class SimpleAuthorityMapper implements GrantedAuthoritiesMapper,
InitializingBean {
private GrantedAuthority defaultAuthority;
private String prefix = "ROLE
";_
This is why it was working for the ADMINISTRATOR- and AUTHENTICATED-roles which which are system-roles in GeoServer (ROLE_ADMINISTRATOR and ROLE_AUTHENTICATED: https://docs.geoserver.org/stable/en/user/security/usergrouprole/roles.html).
To get it working you had to add the prefix „ROLE_“ to the GeoServer-roles.
Example:
Keycloak-role: „KC_GEOSERVER“
the role in GeoServer had to be named like this: „ROLE_KC_GEOSERVER“
This is not the expected behaviour. Usually you want to use exactly the same rolenames in GeoServer and Keycloak.
I have found the place in the GeoServer-Keycloak-plugin-code to fix this:
https://github.com/geoserver/geoserver/blob/master/src/community/security/keycloak/src/main/java/org/geoserver/security/keycloak/GeoServerKeycloakFilter.java#L63
old code:
public GeoServerKeycloakFilter()
{ this.adapterTokenStoreFactory = new SpringSecurityAdapterTokenStoreFactory(); this.authenticationMapper = new KeycloakAuthenticationProvider(); authenticationMapper.setGrantedAuthoritiesMapper(new SimpleAuthorityMapper()); }
new code:
{ this.adapterTokenStoreFactory = new SpringSecurityAdapterTokenStoreFactory(); this.authenticationMapper = new KeycloakAuthenticationProvider(); SimpleAuthorityMapper simpleAuthMapper = new SimpleAuthorityMapper(); simpleAuthMapper.setPrefix(“”); authenticationMapper.setGrantedAuthoritiesMapper(simpleAuthMapper); }
Additionally also the Keycloak-documentation should be updated.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100149-sha1:a9f85c2)
Atlassian logo
