I can publish a layer through the REST API. Problem is when I want to change the style name (PUT) before publishing and then pusblish I get an error like:
2020-11-17 12:11:40,643 WARN [geoserver.importer] - Task failed during import: org.geoserver.importer.ImportTask@anonymised.com
java.lang.NullPointerException: Style fileName must not be null
at org.geoserver.catalog.impl.CatalogImpl.validate(CatalogImpl.java:1509)
at org.geoserver.catalog.impl.CatalogImpl.add(CatalogImpl.java:1497)
at org.geoserver.security.SecureCatalogImpl.add(SecureCatalogImpl.java:1226)
at org.geoserver.catalog.impl.AbstractFilteredCatalog.add(AbstractFilteredCatalog.java:542)
at org.geoserver.catalog.impl.AbstractCatalogDecorator.add(AbstractCatalogDecorator.java:473)
at org.geoserver.importer.Importer.addToCatalog(Importer.java:1637)
at org.geoserver.importer.Importer.doDirectImport(Importer.java:1096)
at org.geoserver.importer.Importer.run(Importer.java:964)
at org.geoserver.importer.Importer.runInternal(Importer.java:930)
at org.geoserver.importer.Importer$4.callInternal(Importer.java:1001)
at org.geoserver.importer.Importer$4.callInternal(Importer.java:994)
at org.geoserver.importer.Importer$SecurityContextCopyingJob.call(Importer.java:1032)
at org.geoserver.importer.job.Job.call(Job.java:16)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1130)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:630)
at java.base/java.lang.Thread.run(Thread.java:832)
