[Geoserver-devel] [JIRA] (GEOS-9823) WMS GetMap POST XML requests formatted according to the OGC SLD XML Schemas are not accepted
Robin Houtmeyers created an issue
GeoServer / BugGEOS-9823
Issue Type:
BugBug
Affects Versions:
2.18.1
Assignee:
Unassigned
Components:
WMS
Created:
11/Dec/20 7:28 PM
Priority:
MediumMedium
Reporter:
Robin Houtmeyers
While trying out WMS GetMap POST XML requests (to overcome GET URL character limit issues), I found out that GetMap XML documents formatted according to the OGC GetMap XML Schemas (http://schemas.opengis.net/sld/1.1/GetMap.xsd) are not accepted.
Here is an example:
<sld:GetMap xmlns:sld="http://www.opengis.net/sld"
            xmlns:se="http://www.opengis.net/se"
            xmlns:ows="http://www.opengis.net/ows"
            xmlns:wms="http://www.opengis.net/wms"
            xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
            xsi:schemaLocation="http://www.opengis.net/se http://schemas.opengis.net/se/1.1.0/FeatureStyle.xsd http://www.opengis.net/sld http://schemas.opengis.net/sld/1.1.0/StyledLayerDescriptor.xsd http://www.opengis.net/ows http://schemas.opengis.net/ows/1.0.0/owsAll.xsd"
            version="1.3.0">
  <sld:StyledLayerDescriptor version="1.1.0">
    <sld:NamedLayer>
      <se:Name>sf:archsites</se:Name>
      <sld:NamedStyle>
        <se:Name>point</se:Name>
      </sld:NamedStyle>
    </sld:NamedLayer>
  </sld:StyledLayerDescriptor>
  <sld:CRS>EPSG:32662</sld:CRS>
  <sld:BoundingBox>
    <ows:LowerCorner>-1.1563040908623124E7 4940069.939036611</ows:LowerCorner>
    <ows:UpperCorner>-1.1536922910423303E7 4952386.271745646</ows:UpperCorner>
  </sld:BoundingBox>
  <sld:Output>
    <sld:Size>
      <sld:Width>651</sld:Width>
      <sld:Height>307</sld:Height>
    </sld:Size>
    <wms:Format>image/png</wms:Format>
    <sld:Transparent>true</sld:Transparent>
  </sld:Output>
</sld:GetMap>
This produces the following result:
<?xml version=“1.0” encoding=“UTF-8”?>
<ServiceExceptionReport version=“1.3.0” xmlns=“http://www.opengis.net/ogc” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xsi:schemaLocation=“http://www.opengis.net/ogc http://localhost:8080/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd”>
<ServiceException>
Could not parse the XML for: org.geoserver.wms.GetMapRequest
</ServiceException>
</ServiceExceptionReport>
I found a working example on https://anitagraser.com/2010/06/09/getmap-from-geoserver-using-http-post/ but the use XML does not comply with OGC’s GetMap XML Schemas.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100152-sha1:d8e2c46)
Atlassian logo
